Transmission problem reverse only - Ford Truck Enthusiasts Forums
Old 12-24-2010, 04:41 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4 2004 xlt 5.4 is offline
2004 xlt 5.4 is starting off with a positive reputation.
2004 xlt Supercrew 5.4 169000 klm
Was stopped at light pulled away crossed intersection truck lost power reved but would not go took out of OD no go no forward movement will go in reverse ok
No prior problems had filter changed in september no filings found at that time
Any thoughts what can be gone in it ?? Had it towed to dealer but there closed till dec 28 yikes
Old 12-25-2010, 10:48 AM
Anyone have any idea whats wrong with it ??
Old 12-25-2010, 02:48 PM
Coskid's Avatar
Coskid Coskid is offline
Coskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to behold
When you shift into reverse is the shifter at reverse or does it hit gear further down the line like say around 2 gear or something?
I had a problem like this and all it was the shift cable had come loose and needed to be replaced. It is held on by a plastic connector and cost about $100 to fix.
Old 12-26-2010, 11:07 AM
No reverse is where it should be dial sits on R
Old 12-26-2010, 01:24 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
It sounds like you may have broken the forward clutch drum or one way roller sprags.
Old 12-29-2010, 03:24 PM
Got word today Forward Clutch gone needs to be rebuilt or new one
went new $500 more than rebuild but better warranty and new torque converter.
Old 12-29-2010, 08:16 PM
Coskid's Avatar
Not to bad.
sensor in door problems power stayes on 2004 xlt 5.4 2004 - 2008 F150 4 09-14-2016 05:16 PM
2004 f350 transmission with reverse problem Framer7 2004 - 2008 F150 10 08-08-2016 09:12 PM
Stalls when in reverse FORDFORDFORD48 Modular V8 (4.6L, 5.4L) 0 06-14-2015 10:20 PM
Won't move in reverse 2004 F-150 4x4, 5.4L Automatic ElkGroveDan 2004 - 2008 F150 17 11-23-2010 07:44 PM
1999 Expedition NO REVERSE,,,Help BigMan69 Clutch, Transmission, Differential, Axle & Transfer Case 4 05-19-2006 04:28 PM
Tags
07, 1999, 2007, codes, f150, ford, forward, move, ok, problem, reverse, suv, transmission, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
