1950 226 engine colors? - Ford Truck Enthusiasts Forums
Old 12-24-2010, 01:32 PM
McGiver McGiver is offline
McGiver is starting off with a positive reputation.
Need help with the engine colors on a 1950 226. I assume the the generator, starter, air cleaner, oil filter were all black. The block was a dark red color. The intake I have seems to be a copper color. Does anyone know the intake, exhaust, harmonic balance, heat shield colors. Also when did Ford start using the blue engine paint?
Old 12-25-2010, 10:54 PM
ct50f1's Avatar
ct50f1 ct50f1 is offline
ct50f1 has a great reputation on FTE.ct50f1 has a great reputation on FTE.ct50f1 has a great reputation on FTE.ct50f1 has a great reputation on FTE.
Quote:
I don't have any official source for this but according to the Mac Antique Auto Parts catalog, medium Ford blue is used for all 6 & V-8's from 1966 on.
I can confirm that the paint on my '50 226, which appeared to be original, was dark red. I don't know about the intake and exhaust but would be interested to hear what you find out from others.
Old 12-25-2010, 10:57 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
This might help ya.
Old 12-25-2010, 11:47 PM
CHUCK48-50's Avatar
CHUCK48-50 CHUCK48-50 is offline
CHUCK48-50 has a good reputation on FTE.CHUCK48-50 has a good reputation on FTE.
Wagner's information is pretty accurate, except it should include all truck engines from 1948-51. In addition, it should be noted that a lot more of the 337 engine was assembled before it got painted red. For whatever reason, the only thing that was black was the oil filter,generator and fan. Even the fuel pump and distributor got painted (with a partial bag over the top of them)!
Your starter and manifolds should be red, and your heat shield should be painted black. And the low gloss black he lists is definitely shiny. It probably wasn't the same quality as what was on the body, but not any version of semi gloss, satin, or chassis black, as some like to call it. This goes for anything black under your truck.
Chuck
1950 Ford F1 226 intake and exhaust manifold 3twinridges 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 10-12-2015 09:34 PM
1950 226 engine color Skalywag 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 08-04-2015 04:37 PM
Recommendations for gasket sealer in various places - 1950 Ford F1 3twinridges 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 03-23-2015 01:53 PM
1950 Ford F1 226 cylinder head 3twinridges 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-21-2015 02:27 PM
CC826 Moog coils for cheap 2.5" lift Dlasure2 1987 - 1996 F150 & Larger F-Series Trucks 0 08-15-2013 03:12 PM
Tags
1950, 1950s, 226, 51, black, ci, color, colors, engine, engines, filter, ford, oil, pickup, red, truck, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
