"quote "
Does anyone have a template for the stock 56 Ford F-100 side door glass? "quote"
I have an original piece of side glass that measures 17 3/4" wide and is 17 7/8" high at the wing window and 17 3/8" at the rear where the 2 7/8" radius starts, if this helps.
Thanks John. I actually pieced the stock original broken one together enough to make a pattern. I will check with the dimensions you provided to make sure Im real real close to that. Thanks for your assistance.
