one piece side glass for 56 f100? - Page 2 - Ford Truck Enthusiasts Forums
Old 07-28-2014, 08:27 PM
Outlaw56 Outlaw56 is offline
Outlaw56 is gaining momentum as a positive member of FTE.Outlaw56 is gaining momentum as a positive member of FTE.
Does anyone have a template for the stock 56 Ford F-100 side door glass?
Old 07-31-2014, 01:06 PM
56panelford's Avatar
56panelford 56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
"quote "
Does anyone have a template for the stock 56 Ford F-100 side door glass? "quote"
I have an original piece of side glass that measures 17 3/4" wide and is 17 7/8" high at the wing window and 17 3/8" at the rear where the 2 7/8" radius starts, if this helps.
Old 07-31-2014, 09:58 PM
Thanks John. I actually pieced the stock original broken one together enough to make a pattern. I will check with the dimensions you provided to make sure Im real real close to that. Thanks for your assistance.
Is back glass easy to replace or...? OJs DNA 1999 to 2016 Super Duty 2 03-14-2017 06:20 AM
Window fuzzies smallello 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 06-02-2016 08:29 PM
steel wool 0000 .... water spots traxx808 1987 - 1996 F150 & Larger F-Series Trucks 4 06-27-2014 10:24 AM
'56 f100 solid side window vs vent hwyhogg 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 03-13-2014 01:15 AM
Replacing 2001 F350 side mirror glass stevech 1999 to 2016 Super Duty 0 10-22-2012 10:37 AM
Tags
1956, 56, door, f100, fitting, ford, glass, installation, instruction, kit, pickup, piece, problems, side, solid, truck, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
