Adding rear disc brakes pre 97 f350 - Ford Truck Enthusiasts Forums
Old 12-24-2010, 11:42 AM
tcshop's Avatar
tcshop tcshop is offline
tcshop is starting off with a positive reputation.
Is there a kit available to add rear disc brakes to my 96 F350 w/srw, or a known conversion using later model parts?
Old 12-24-2010, 11:43 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Yes. But you will be dissapointed. Just keep the drums
Old 12-24-2010, 11:46 AM
zxwut?'s Avatar
zxwut? zxwut? is offline
zxwut? is gaining momentum as a positive member of FTE.zxwut? is gaining momentum as a positive member of FTE.
Just out of curiosity, what makes you think he'd be disappointed? There'd be no opening them up all the time to clean and lubricate the "self adjusting" drums, pad replacement would be simpler, it'd have more braking power, especially when hauling, etc.
Old 12-24-2010, 12:58 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
http://www.ford-trucks.com/forums/10...disc-swap.html Have a read here, although his will be a different axle.
Also check out egrbrakes.com for a complete kit.
Old 12-24-2010, 03:20 PM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
There are a few guys on NLOC putting alot of time into researching FACTORY ford rear disk brakes and bigger front brakes for our trucks.
Rear brake link.
9.75" rearend upgrade? - The National Lightning Owners Club Inc
Old 12-24-2010, 09:26 PM
Quote:
EVERY rear disc brake kit conversion i have heard or seen does not stop as well as the factory drum brakes.
I know i can lock up my drum brakes just fine and they have over 150k on the original shoes.
Blackbirds makes a conversion kit & TSM also makes a kit, but both of these use cadaillac eldarado caliper to retain the e-brake. But you are using a CAR caliper to try and stop a 6500+lb truck. Not to smart in my book, b plus they dont stop to well and warp rotors from getting hot
there was a conversion i seen a guy used a 98 and newer van rear dis brakes and adaped them to his 97 10.25.It stopped very welll. I think i would of just used the van axle, but a van uses a lighter axle than a pick up. he had to have several one off machined parts made$$$$$$$$$$
Old 12-24-2010, 09:47 PM
zxwut?'s Avatar
I understand now. Thanks.
1993 F350 4x4 Rear Disc Brake Conversion Wilde Ford 1987 - 1996 F150 & Larger F-Series Trucks 29 01-03-2017 05:43 PM
'05-'07 Brake caliper torque specs BjornF16 6.0L Power Stroke Diesel 2 11-18-2016 04:17 PM
2013 Has Larger Brakes supeRobertduty 6.7L Power Stroke Diesel 28 10-05-2015 09:58 AM
Disc brakes instead of drums Callantom 1987 - 1996 F150 & Larger F-Series Trucks 23 05-08-2010 02:39 PM
Rear disc brake swap Jaaaaaaackman 1994.5 - 1997 7.3L Power Stroke Diesel 5 01-02-2010 12:08 PM
Tags
350, 86, 96, 97, 97f350, brake, brakes, conversion, disc, disk, display, f250, f350, kit, rear, wwwvanaxlecom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
