computer won't clear on 2002 ford expedition
Reset PCM by disconnecting either KAM fuse or battery negative cable for 10 minutes, then reconnect and drive for a week or two before re-testing.
If the original fault codes are still present at that time, all it means is that you didn't fix anything and the original problem is still there.
