Dana 60 rear disc brake conversion
certainly seems like a pretty reasonable price for a win win item. i have to buy all new drums shoes cylinders, the whole nine anyway so why no go to something better and something that will preform better?
he's right on the year rotors and calipers to use but as far as brackets go i made my own for free
I just used a piece of construction paper and made it work. The only critical thing is the hole centers and tapped.
I like this design so I could clock it perfect to allow the bleeder screw to sit vertical AFTER I rotated my diff up for my cv driveshaft. The axle points up about 20 degrees with my lift so i dont think a stcok bracket would of worked as well.
As for brake line stainless is nice but mine i searched through a brake line catalogue and found these from a 80's chevette car!! 10$ each and works great with enough length to still service pads.
As you can see its been sitting for awhile now...
This is actually a D70 rear axle but same thing. Even my diff cover was described to fit a dana 60 but I knew they interchange
and now you need a parking brake!
This is what i use
its a mechanical ball valve line lock using brake pressure. Hold brakes on then twist valve.
It pretty badass.
I put mine here
It makes it easy to install and is in a good accessible spot.
I love it offroad on a hill i engage it, then with foot on gas and clutch i gas it on the hill then twist the line lok off so i have zero roll back and just go straight up.
Also on a tight corner i put it on, engage my twin stick t case to front wheel drive only, then crank wheel hard in direction needed then gassing it pivot off my back tires on a dime turning corner. Who does that in there 73 Dent lol
This is what i use
It pretty badass.
I put mine here
Here's a couple I have saved that show the part #'s etc. for the 8 lug trucks.
1977 Ford F250 4x4 - Dana 60 Disc Brake Conversion
https://www.ford-trucks.com/forums/8...sc-brakes.html
This is what i use
It pretty badass.
I put mine here
This is what i use
It pretty badass.
I put mine here
This is what i use
It pretty badass.
I put mine here
This is what i use
It pretty badass.
I put mine here
We call those micro brakes
