Injector O-ring replacement
Technically, you are not supposed to service them. Having pulled one apart myself back when the support rings were failing I can tell you that using a pick is the only way but you risk damaging the injector. By the way, why are you removing that seal and were did you get the service part? I know of a source, I am just curious.
Good to hear. I had another thread on the subject and no response.
Changing the injectors over to a new long block and didn't keep the original order. Have yet to read anything on changing the top of the injector o-rings so worried i might have missed something ? So critical to ensure there are no leaks.
Thanks for your response.
Nathan Cox
07-05-2016 09:54 AM
dieselboy427
08-12-2009 11:32 AM
