hub actuator - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
hub actuator
Old 12-23-2010, 09:14 PM
jonsan13 jonsan13 is offline
jonsan13 is starting off with a positive reputation.
hub actuator
I need to know if a 1999 Expedition has the vacum locking hubs
I have looked on top of the axle and do not see any actuator only a hose running to the underr side of the battery. It looks like there is a plastic screen on the end of the hose. Any info would be greatly appreciated -Thanks
Old 12-23-2010, 10:23 PM
Z06PSI's Avatar
Z06PSI Z06PSI is offline
Z06PSI is starting off with a positive reputation.
My 2005 Auto 4WD Navi has the IWE (Integrated wheel end).
Old 12-23-2010, 10:53 PM
brzehentmaier brzehentmaier is offline
brzehentmaier is starting off with a positive reputation.
I am pretty sure the hose with the screen on it is just a vent. I rerouted mine on my YJ so I could go through deeper water. Purchased my exp. 4 months ago and haven't had time to do much work or research on the truck yet.
Bernie
Old 12-24-2010, 10:45 AM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
I don't believe the hubs on your truck are vacuum operated. I couldn't find any refernce to it in my manual.
Old 12-24-2010, 12:31 PM
Big Greenie Big Greenie is offline
Temporarily Deactivated
Big Greenie is gaining momentum as a positive member of FTE.
The 1999 model does not offer the 2wd setting, and does not have the vacuum disconnect function. The front driveline is always engaged.
Old 12-24-2010, 03:40 PM
thanks makes sence
Old 12-24-2010, 08:39 PM
Z06PSI's Avatar
I should have been clearer... mine are vacuum operated.
Everything You Wanted To Know About The IWE System...And Then Some xjcamaro89 2004 - 2008 F150 404 01-03-2017 12:59 PM
4x4 vacuum hubs won't disengage Jxltrucking 1999 to 2016 Super Duty 6 01-04-2016 02:54 PM
97 4x4 Hub and rotor am I sane question iamvandemon 1997 - 2003 F150 4 03-11-2015 11:01 AM
wheel hub & actuator ramhunter5877 2004 - 2008 F150 2 02-22-2015 03:41 PM
Replacing Ignition actuator rod in steering column ? West Coast Bronco 1978 - 1996 Big Bronco 1 03-05-2004 11:06 PM
Tags
150, 2003, 2010, 4x4, actuator, end, expedition, ford, hub, hubs, integrated, locking, navigator, vaccuum, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
