Lost Power!! - Ford Truck Enthusiasts Forums
Lost Power!!
Old 12-23-2010, 09:04 PM
Bwillden24's Avatar
Bwillden24 Bwillden24 is offline
Bwillden24 is starting off with a positive reputation.
Lost Power!!
I've been working on my '80 F100 for about a month and a half now and have been doing some great work for teaching myself as I go. Just recently my Bro-In-Law has been over and decided to work on my truck while I was out there and now I can barely get the truck to move. I think that all he did was fiddle with my carb, any ideas??
Old 12-24-2010, 10:25 AM
bertha66's Avatar
bertha66 bertha66 is offline
bertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud of
If he was messing with the carb, check the air mixture screw, turn it in to it stops, do not tighten, then open @ 2 turns and see how it runs. Did he change the timing?
Old 12-24-2010, 06:13 PM
Bwillden24's Avatar
I dont think he did anything to my timing but I know he changed the vacuum line cluster around to nearly nothing.
Old 12-24-2010, 08:21 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
Where did he hook the vacuum advance line from the distributor to?
Old 12-24-2010, 08:45 PM
Bwillden24's Avatar
to the carburetor
Old 12-24-2010, 08:57 PM
Old93junk's Avatar
Make sure it is to the ported vacuum advance location and not just manifold vacuum.
Old 12-24-2010, 09:09 PM
Bwillden24's Avatar
I am rebuilding my carb right now, then I'm going to check all vacuum lines and make sure they are in the correct spots.
Old 12-24-2010, 10:21 PM
Bwillden24's Avatar
Carburetor disassembled, now to clean the whole thing up and make sure theres no gunk and put it back together
Old 12-24-2010, 10:24 PM
Old93junk's Avatar
Thats the autolite 1bbl right?
Ever think of going to a Offenhauser intake and a holley 3904bbl carb?
Old 12-24-2010, 10:35 PM
Bwillden24's Avatar
its the motorcraft(carter) 1bbl, and no I haven't, i've just been trying to get my truck on the road, I found the label for my carb and got it cleaned off so I can actually read it, how do I depict what the model is from this:
EOTE CA
AO E 5
Old 12-24-2010, 10:41 PM
Old93junk's Avatar
Take it (metal label tag) down to Knechts, they will give you the right kit.
Should be a breeze, pay attention to the float settings.
Old 12-24-2010, 10:44 PM
Bwillden24's Avatar
i already have the kit, all the pieces match up and so do the gaskets
Old 12-24-2010, 10:46 PM
Old93junk's Avatar
Your good to go then............just find a clean place to work, and good light.
I use the kitchen table, wife HATES it!
Old 12-24-2010, 10:47 PM
Bwillden24's Avatar
heres what it looks like right now
Old 12-24-2010, 10:48 PM
Bwillden24's Avatar
thats exactly what i'm using, parents weren't to happy but hey Its cold outside cant blame me
Dizzy O-Ringy Thingy hermancm 1973 - 1979 F-100 & Larger F-Series Trucks 11 08-27-2013 08:44 PM
now the site works drewdole Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 03-02-2012 05:22 PM
Air conditioning -HELP katbird704 1994.5 - 1997 7.3L Power Stroke Diesel 10 07-24-2010 03:38 PM
Rotors wylecoyote Excursion - King of SUVs 27 11-10-2006 09:50 PM
Been gone awhile! BlkButy Kansas Chapter 1 11-14-2004 07:18 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
