2004 f150 5.4 4WD won't engage (newbie) - Ford Truck Enthusiasts Forums
Old 12-23-2010, 07:40 PM
drshort drshort is offline
drshort is starting off with a positive reputation.
I've spend the past couple of days reading every F150 4x4 problem post I could find. It's been a big help, but I'm still having some issues. I recently bought this 2004 F150 5.4 and the 4WD systems appears to need some care in multiple areas.
Problem #1 (Fixed): Transfer case engaging, but not disengaging 4 Hi / 4 Lo
A few days ago, I turned the switch to 4 Hi. It went into 4 Hi and light went on, but wouldn't come out when I switched back to 2 Hi. It turns out there is one relay to engage and another to dis-engage the external transfer case motor. (one relay does counter clockwise, the other does clockwise). I replaced both relays located under the hood and now the transfer case shifts in and out of great as it should. Fixed. I also replaced the transfer case motor, but that seems unnecessary in hindsight.
Problem #2: Wheel hubs (IWE) not locking.
When I am in 4Hi, it appears the front hubs aren't locking. I've read everything I could about the IWE system and replaced the solenoid on the firewall.
I pulled the vacuum lines at each wheel hub. I have strong vacuum on the passenger side when in 2 Hi and it goes away when I switch to 4Hi (as it should). The vacuum on the drivers side feels very weak. There must be a leak somewhere? Any place to focus on?
Vacuum keeps the hubs dis-engaged. So if I can turn off the vacuum by switching to 4 hi, why aren't the hubs engaging? Can the IWE actuators get stuck in the dis-engaged position? I've never heard any of the grinding or other noises people sometimes get on these front hubs, but who knows about the previous owner.
Any help would be greatly appreciated.
Old 12-24-2010, 10:50 AM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
It's possible for the IWE to be not engaging. If you read XJCAMARO69's writeups on the IWE system, I think nearly everything is covered on what to check.
Old 12-30-2010, 01:33 AM
Just an update n the 4wd not engaging.
Both IWE actuators were shot. One had a vacuum leak. This appears to have caused the other side to lose vacuum and grind over time causing the teeth to be very worn on both IWE and hub.
Old 12-30-2010, 06:50 AM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
...and to answer your question, yes the IWEs can fail internally. My right side IWE was actually broken/jammed. When I removed it there was a lot of dried burnt looking residue (used to be grease) inside it.
Old 12-30-2010, 12:18 PM
Oh, how I long for the simplicity and reliability of the old fashioned manual locking hubs and manual transfer case on an F150.
Old 12-30-2010, 05:12 PM
60DRB's Avatar
If only that stupid bee-a%#! hadn't run head-on into my good old '92 F-150... At least this new system is easy to repair.
Old 12-30-2010, 08:07 PM
xjcamaro89's Avatar
xjcamaro89 xjcamaro89 is offline
xjcamaro89 is gaining momentum as a positive member of FTE.
Quote:
Its xjcamaro89.....just sayin, lol!
Old 12-30-2010, 09:52 PM
xj, I assume everything is good with your truck now that you've done all the work on it.
Old 12-30-2010, 09:57 PM
xjcamaro89's Avatar
Ya, i think im good.
Old 12-31-2010, 08:23 PM
Cool. Happy new year to all.
'06 Expedition 4wd problems and IWE solenoid questions WWR Expedition & Navigator 10 02-25-2016 11:06 PM
2005 F150 4x4 Noise/Troubleshooting nfazer 2004 - 2008 F150 4 12-07-2014 11:19 PM
IWE (4WD) Vacuum Test & Results Ranger Bob 2004 - 2008 F150 12 01-31-2014 06:35 AM
4WD vacuum line '98 Ranger PUZZLED gpdickert Ranger & B-Series 1 07-04-2013 10:01 PM
IWE PROBLEMS! Need Help wats504 2004 - 2008 F150 7 01-20-2011 06:40 AM
Tags
150, 2004, 2005, 4wd, drive, engag, engage, engaged, f150, ford, forum, fuse, hubs, pull, switch, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
