transmission
Old 12-30-2010, 10:51 PM
kdiddy's Avatar
kdiddy
kdiddy is offline
transmission
I have a ford f150 fx4 with 45,000 miles on it. I noticed when i am driving uphill at approx 40-50 mph my truck begans to jerk. I was wondering if it is my transmission slipping or I just need to change my transmission fluid ( which I have not done yet). Would anyone recommend "Royal purpal" tranny fluid???
Old 12-30-2010, 10:53 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Its not jerking it sounds like it is "hunting" for gears in which case you should turn the OD off.
Old 12-31-2010, 05:39 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,221 Likes on 803 Posts
Knowing the year of the truck would be very helpful. If it's an '08 or older, it's pretty close to the time for a transmission service / flush / change, pick your poison. If it's and '09 or newer, it's possibly hunting for gears.
Old 12-31-2010, 07:24 AM
juneau76's Avatar
juneau76
juneau76 is offline
According to his profile, he has a 2007.
Old 12-31-2010, 09:16 AM
kdiddy's Avatar
kdiddy
kdiddy is offline
My overdrive is off, actually I never use it too much. It does feel like its searching for gears, but its already in 4 th gear. It feels like it going between 3 rd and 4 th gear. Why is that???? Is it my tranny fluid? I haven't changed it yet.
Thanks.
Old 12-31-2010, 09:24 AM
efx4's Avatar
efx4
efx4 is offline
If you are driving up hill, the trans. going between 3rd and 4th would be common, especially if the grade is a bit steep.
Old 12-31-2010, 11:24 AM
stephen.osborne1's Avatar
stephen.osborne1
stephen.osborne1 is offline
This is the wrong thread for an 07, but be sure to get a stress test done on your coils... I had one that would intermittently miss under load (like going uphill) and it felt like the trans was slipping. One mechanic tried to sell me a new trans... Then I got the stress test done and replaced one $50 coil. No problems since.
Old 12-31-2010, 02:16 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Thread moved.
Old 12-31-2010, 02:59 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Plug, coil or coil boot. Misfire under heavy, low rpm loads.
Old 12-31-2010, 03:04 PM
kdiddy's Avatar
kdiddy
kdiddy is offline
Well its not under a heavy load , actually no load. When its in 4th gear its a small jerking feeling. But now that I think of it I don't think its going between gears. At first I thought I had a flat.
Old 01-01-2011, 09:30 AM
Coskid's Avatar
Coskid
Coskid is offline
Flush the tranny and change the filter you are at the point that it should be done. I usually do mine every 40k which is a bit shy of what is recommended but helps to prolong the life.
Also OD should only be turned off when under a load or on steep inclines. You should be using it the rest of the time. This may help other parts of your truck run better to if you leave it on for a bit.
sbrodacz
03-07-2013 12:33 AM
dieterschmied
04-18-2011 10:20 PM
ultrartwing
08-31-2006 04:47 PM
Psychoboys
04-02-2006 08:36 PM
ralphnaderrules
General Automotive Discussion
11-05-2004 05:14 PM
Quick Reply: transmission
