"Popping" noise in exhaust - Ford Truck Enthusiasts Forums
Old 12-23-2010, 03:51 PM
mr_ranger-79's Avatar
mr_ranger-79 mr_ranger-79 is offline
mr_ranger-79 is starting off with a positive reputation.
My truck when idling has this "popping" sound coming out of the exhaust. Is this a mal-adjusted carb or a carb that is needing rebuilt? This is a 1979 F-250 4x4 with the 400 and 4 speed manual. I don't know exactly what carb it is. It is a 2-bbl motorcraft. Which I assume is the stock carb but not sure. It does run real strong though. I think it is suffering a bit in the mileage area. Even though economy and these trucks don't often reside in the same sentence. Any help would be greatly appreciated...thanks.
Old 12-23-2010, 04:06 PM
Fish_Scientist Fish_Scientist is offline
Fish_Scientist is starting off with a positive reputation.
Quote:
I'm no expert, but if you hear a "popping" sound coming from the exhaust, that would lead me to believe that you've got an exhaust leak. Is the noise coming from near the engine? Maybe it's a blown exhaust manifold gasket. Maybe a bad exhaust joint somewhere.
Fish
Old 12-23-2010, 04:09 PM
I just hear it coming out of the end of the exhaust. This had headers and glass packs. It appears to be professionally installed. It was on the truck when I bought it. It seems to run really strong to be much of a carburation problem...I have had plenty of vehicles with bad carburetor problems. Hell my 1975 F-250 carburetor caught on fire once!!
Old 12-23-2010, 07:21 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Start with a vacuum gauge and see how steady it is. Try pulling plug wires one at a time (insulated plug wire puller) and see what changes. If you find one cylinder where nothing changes, there is a problem. Might take a compression check to determine what the problem is.
Old 12-23-2010, 09:00 PM
nothercrash's Avatar
nothercrash nothercrash is offline
nothercrash is starting off with a positive reputation.
Popping in the exhaust means something is detonating in the exhaust. Or at least at the wrong time in the engine.
Is the exhaust true duals (no crossover between the sides)? If it is, does the pop only come from one side?
How loud is the pop?
Is the pop regularly timed (rhythmic, equally spaced, as in a problem that occurs in one cylinder every time it fires)? Or is it random?
Does it happen when the engine is cold, warm, idling, in gear stopped, driving?
Where exactly is the pop coming from along the truck?
Is there a pressure jump or drop at the tailpipe associated witht he pop?
Need way more info to even theorize on the problem, but I doubt it's a problem with the exhaust system.
AleX
Old 12-23-2010, 10:50 PM
AleX
It is a true dual exhaust with headers and glass packs.
The popping noise isnt real loud, maybe as loud as a champagne cork...give or take a little.
I will have to listen to it next time to determine which side it is coming from if it isnt both sides.
The pop is definetely random.
I have only noticed the pop when it is at idle and warmed up.
I just hear the pop at the tailpipe...again I will have to listen more carefully next time.
Old 12-23-2010, 11:07 PM
lonnie1952 lonnie1952 is offline
lonnie1952 is starting off with a positive reputation.
I had the same exact issue with my 390
Worn throttle shaft on the motorcraft 2bbl carb was causing a vacuum leak. Carb rebuild with Shaft bushing fixed the problem
Lonnie
Old 12-24-2010, 03:11 AM
I was thinking if it was something simple and cheap I would try to fix it, otherwise I will deal with it. It isnt that bad (just annoying more than anything else) and I will be putting in a new motor this summer. If it is something that a carb rebuild would fix I would be willing to do that as the kits are pretty cheap. If it is something down in the motor itself then no way...I can deal with it until the new motor goes in. Thanks to all for your replies, like always your help is appreciated very much.
What am I seeing Mtnhermit 1999 to 2016 Super Duty 10 04-30-2016 01:57 AM
4.9 (Carb) Running VERY lean bg_ 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 02-26-2015 05:31 PM
1978 302 timing setting thumbs08 1973 - 1979 F-100 & Larger F-Series Trucks 5 04-16-2012 08:42 AM
Need to re-tune carb after headers/exhaust? mktsc 1973 - 1979 F-100 & Larger F-Series Trucks 24 03-17-2012 07:14 PM
Pops truck needs carb ManhattonNite 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 12-09-2003 03:14 PM
Tags
check, coming, compression, dual, exhaust, ford, idle, jubilee, making, noise, pop, popping, side, slight, sound, true
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
