Ontario Chapter Join Chapter>, Leader: loudfords
clutch install
Old 12-23-2010, 02:03 PM
k_nine's Avatar
k_nine
k_nine is offline
clutch install
does anyone have a good picture or explored diagram of a clutch and how it goes together?
going to order all the parts soon just like to see how everything goes together, this way i'm ready.
thanks
Chris
Old 12-26-2010, 08:47 AM
garywh's Avatar
garywh
garywh is offline
better buy a haynes book at ctc,,,order the clutch with matching pressure plate and bearing,,and you may need slave also
Old 12-26-2010, 08:59 AM
k_nine's Avatar
k_nine
k_nine is offline
May truck was a stick before but your right i might need a new slave i was looking at mine not sure if its all there and will seal properly.
i went to napa to to price everything, clutck was 225.00, that was a complete clutch kit.and clutch fork is 52.00, I still need a new trans mount and should get the slave.
i went through the haynes manual but didnt see a very good pic of the clutch stuff.
Old 12-28-2010, 10:00 PM
fp_5's Avatar
fp_5
fp_5 is offline
Buy everything, return what you don't need. Napa is great that way. Better to have it on hand when you drop the transmission, if anything looks suspect replace it. As a rule I always change the pilot and throw out bearings when I do a clutch. If I have time I get the flywheel resurfaced.
Frank
Old 12-28-2010, 10:26 PM
k_nine's Avatar
k_nine
k_nine is offline
Believe me everything is going to be new, I dont have much of a choice i didnt even get a transmission with this truck, I got to drive it 5 times then the replacement(c6) i got went on me. the truck orginally had a 4 speed in it then i coulnt find anything to replace it with, then i found a parts truck switch it to an automatic. now I cant find one to replace that with then last 2 weeks ago i came across a t-19 for 200 bucks. So it's going back to a stick.
I'm going to do what i can to get this truck running again, I cant wait
BIGKEN
Massachusetts Chapter
559
08-12-2022 08:11 AM
Nash Bridges
60
05-12-2012 02:15 PM
arecycling77
27
05-11-2011 02:36 PM
k_nine
15
03-06-2011 01:43 AM
ItsABeautClark
1999 to 2016 Super Duty
08-19-2010 06:27 AM
Quick Reply: clutch install
