8 Injector circuit's low, 1 High, FICM?
I went down to Marysville and home yesterday. Approximately 500 miles round trip. Throughout the trip I got all of these codes. I looked them up and apparently every injector has low voltage, and cylinder 10 has high voltage? (I realize I don't have a cylinder 10)I couldn’t find the U codes in the pdf from the tech folder. Anyone know what those might be? I called my dealer and she said it was a body code, meaning a wiring harness was wearing.
The truck is 2003 F250 6.0l auto. It has about 190k miles. The batteries died while I was in Idaho on a hunting trip, jumped it to get home, and it’s started fine since then. My monitor is showing my voltage at about 13.2 which I know is a little low, but that’s what it’s always been since the monitor was put on… With all 8 injectors showing low voltage is it safe to assume it’s the FICM?
Codes
PO261
PO264
PO267
PO270
PO273
PO276
PO279
PO282
PO289- Cylinder 10 injector circuit high
P1000-OBD System Readiness test not complete
U2760?
U30e0?
Codes
PO261
PO264
PO267
PO270
PO273
PO276
PO279
PO282
U2760?
U30e0?
The odd codes strike me as, well, odd. I may be way off but I wonder if your low battery condition didn't cause a bunch of errant codes.
This is just my opinion. If you feel capable, there is a set of instructions in the tech folder at the top of the page for checking the FICM voltage. I would do that. If it's OK. I would clear the codes and see if they return.
A bad FICM will cause all 8 injector codes. But I just wonder if the low battery voltage condition didn't throw them also and you really don't have a problem beyond that.
Also, 13.2 volts with the engine running after the glow plugs shut off is OK. The Ford recommended range is 13 to 15 volts. As long as you are maintaining a good battery charge I don't see a problem.
Ya. I cleared the codes after they first showed up to see if they were coming back. They came back with the P1000 code.
I still haven't gotten around to testing the FICM with Christmas being all hectic here, but after I cleared them again they came back with P0273 and P1000, then the next morning everything went away and I haven't had a code in a few days now...
Jim McGuire
03-26-2016 04:14 PM
ScottKrieger
08-31-2014 09:52 PM
