2008 Ford F-350 SD Crew Cab with 8' Fisher Plow
Has anyone run into the problem with diminished cab heat as well as outside temp gauge going above 100 F , when plowing and traveling with the Fisher plow? This has happened to me in the past with a Curtis plow but I thought with a Fisher these problems might go away. I guess not.
Your plow is blocking the factory outside temperature sensor from air flow and causes the automatic climate control to not work properly. There is a TSB 08-14-4 to fix this. It relocates the temperature sensor to another location that is not blocked by the plow. The part # is 8C3Z-14A411-C. This may be covered if still under factory warranty. Otherwise the kit comes with instructions.
JMyers0901
09-29-2011 07:05 PM
