clutch on a 94 Ranger - Ford Truck Enthusiasts Forums
Old 12-22-2010, 11:28 PM
danielwd danielwd is offline
danielwd is starting off with a positive reputation.
94 Ranger, 170,000 miles, 2.3 L
I replaced my clutch, pressure plate, slave cylinder, and had my flywheel resurfaced. I bled my slave cylinder twice following Haynes instructions, and I'm still having problems which I don't even think stem from my new clutch.
I cannot shift gears at all, with the truck NOT running, or with the truck running. I have inspected the throw out bearing push against the pressure plate from underneath the truck through the inspection port under the bell housing, and I can see it move against the pressure plate.
But what really makes me curious is the fact that even when the truck is not running at all, I cannot shift out of neutral into any gear with or without pushing the clutch pedal down. This issue should not be connected to the clutch at all because the truck is not even on and I'm not even engaging or disengaging the clutch. It makes me feel as though there is now something wrong with my transmission, but it was fine before.
Here's another kicker! After I start the truck, if I take my foot off the clutch pedal, the truck stalls!
Any suggestions...thanks in advance.
Old 12-23-2010, 02:36 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
My guess would be that somehow the transmission input shaft (mainshaft) is jammed hard against the flywheel. Either due to a wrong pilot bearing or wrong/distorted clutch plate.
If it was me I would pull the transmission again and have a look.
Old 12-24-2010, 10:23 AM
stuart1 stuart1 is offline
stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.
I answered in a different fourm and this has been corrected.
The stick was not aligned with the shift rails.
Clutch issue with my '94 2.3 stephano Ranger & B-Series 12 05-21-2011 11:17 PM
94 clutch - ford ranger danielwd Ranger & B-Series 21 12-27-2010 05:47 PM
How much travel distance should a clutch slave throwout bearing move? fordopie Ranger & B-Series 5 09-02-2009 05:56 AM
1995 Ranger Clutch/Slave Cylinder glenn65 Ranger & B-Series 16 12-31-2005 12:16 AM
'90 Ranger Transmission/Clutch trouble Gov Ranger & B-Series 1 10-30-2004 09:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
