1986 F-150 specs - Ford Truck Enthusiasts Forums
1986 F-150 specs
Old 03-04-2003, 05:16 PM
skycarpslayer skycarpslayer is offline
skycarpslayer is starting off with a positive reputation.
1986 F-150 specs
I have a 1986 F-150 4x4 w/302 FI and i was wondering what the standard axels were and what kind of gearing they had because im thinking of putting lockers and maybe different gearing in it.
Old 03-04-2003, 05:42 PM
brown 4x4 brown 4x4 is offline
brown 4x4 is starting off with a positive reputation.
1986 F-150 specs
You would have a Dana 44 Twin Traction Beam in front. In back, it's probably the 8.8" Ford, but a 9" is possible. The 8.8" has a removable cover, 9" doesn't. Look for a tag on the diff for the gearing, or just post the axle code from the door jamb sticker and we can decode it. That's assuming the gears are still factory.
Old 03-04-2003, 06:27 PM
1986 F-150 specs
is it possible to have almost a independent front suspension because thats what it looks like to me....although im not an expert thats why im asking
Old 03-04-2003, 08:08 PM
1986 F-150 specs
Yeah, that's what the twin traction beam (TTB) is. I guess you could say it's a D44 chopped in half that pivots at the center. This setup was used from 80-96 on 1/2 and 3/4 ton trucks, except heavy duty 3/4 tons used a Dana 50 ttb.
1986 F150 fuel pump pressure Gene Beckstead 1987 - 1996 F150 & Larger F-Series Trucks 3 06-01-2014 11:03 AM
fuel pump pressure 1986 f150 Gene Beckstead 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 06-01-2014 07:43 AM
Need help with part number, please! 1986F150six 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 06-20-2013 08:09 PM
1986 ford f150 4x4 shifting pattern 1986 ford blue f150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 08-24-2011 01:24 PM
1986 F350 CC DRW Towing capacity 2001gocougs 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 10-09-2007 11:03 PM
Tags
150, 1986, 1986f150, 86, f150, ford, gvw, specifications, specificiations, specs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
