1952 magic air emblem - Ford Truck Enthusiasts Forums
Old 12-22-2010, 06:59 PM
fifty-two_f1's Avatar
fifty-two_f1 fifty-two_f1 is offline
fifty-two_f1 is starting off with a positive reputation.
Okay so I had a decal made to fit my blanks. What do you guys think? I only made one so will anyone be interested?
Old 12-22-2010, 07:00 PM
Picture problems.
Old 12-22-2010, 07:02 PM
By the way...... I love to hate photobucket
Old 12-22-2010, 07:46 PM
firstrider's Avatar
firstrider firstrider is offline
firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.
That will work . Still am going to inquire about the repro of this motor cover badge .All concure this is from a '52 5 * extra cab ? I think this one will find its way onto the Magic Air heater in the 1ST-RIDE . That means I will have a regular blue/ lght yellow heater badge for one of the restored heaters . whoops , forgot pic .
Old 12-22-2010, 07:48 PM
firstrider's Avatar
Old 12-22-2010, 07:58 PM
Denny, I think the 52 badge was for all models in 52 regardless of the 5 star package. Also I think that they were all suppose to be red and the yellow is from fading.
Old 12-22-2010, 08:08 PM
jaye's Avatar
jaye jaye is offline
jaye is starting off with a positive reputation.
52-f1 that is sweet how did you make it
Old 12-22-2010, 08:11 PM
Quote:
I used the same blanks as the 51s but had a different decal made. I had my local sign shop do it.
Old 12-22-2010, 08:13 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
Quote:
I think you're right, Jordan. My '52 V8 M-H is a base 5 Star with a Magic Air. Here's another pic of an original '52 badge. Stu
Old 12-22-2010, 10:00 PM
BlueOvalRage's Avatar
BlueOvalRage BlueOvalRage is offline
BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.
I'm with Stu. My standard cab '52 has a Magic Air with the same badge. The repop looks great, Jordan. MYLAR "FORD" LETTERS! LOL!
Old 12-23-2010, 01:06 AM
Mervy49's Avatar
Mervy49 Mervy49 is online now
Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.
Those look great. They are a little different than the one on my heater. I'll get a pic tomorrow since it is late here. Mine has the little tabs missing, they get metal fatigue easy and tend to break off. I'll get back on here tomorrow.
mervy49
Old 12-23-2010, 05:07 AM
I've had a conversation a while back with Mark Mossell, the chassisman, about badge restoration. He's made a buck in the shape of the face contour and has been able to work out the dents and scars on his badge. Same idea as with stainless trim repair, tapping it to shape then dressing with a file. He's also had luck making new aluminum tabs out of slightly heavier stock. As I recall him saying, he made them in a "T" shape then JB Welded the top of the "T" where the original tabs had broken off. Once installed the repair can't be seen. To me it would be worth trying, especially to preserve one of these '52 badges that has the raised image. Stu
Old 12-23-2010, 12:36 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
I'm still on the hunt for at least one of the original 52 badges.
Old 12-23-2010, 02:42 PM
thechassisman's Avatar
thechassisman thechassisman is offline
thechassisman is starting off with a positive reputation.
I made a dolly out of 1/2 inch steel with a 1/2 inch rod welded to the back, fits inside the 1952 Ford Magic Air heater emblem. hitting with a rubber hammer brings them back to perfect overall shape. also the little aluminum tabs I made to JB weld to the inner rim. curve them to match the inside contour then hold them inside to mark where they will go before grinding the broken tab stubs completely off. number them for their new position unless you make them all perfectly the same. Even the best tabs have only a couple bends left in them , so I replace all 4 no matter what. Works perfectly.
Old 12-23-2010, 02:48 PM
Hey Mark! Would you be interested in doing some resto work or renting your dolly? My badge has a couple dings around the rim that need straightened but I'm not brave enough to do it for fear of making it worse. A couple of the tabs look iffy also. That's why I've been encouraging Jordan to try to come up with a passable repop of this badge. It obviously won't have the raised lettering or be original, but most people won't know the difference anyway. My truck is going to get used. A lot. I'd hate to get my badge all restored and have somebody kick it or scrape it with something and ruin it again. I still want to get my original badge restored, though.
1964 F100 New to me NRGarrott 1961 - 1966 F-100 & Larger F-Series Trucks 5 06-23-2012 10:48 AM
Gauges Arrived Today emery72 1999 - 2003 7.3L Power Stroke Diesel 53 03-19-2012 12:52 AM
01 to 05 facelift "THE HARD WAY"!! Smokiesman 1999 - 2003 7.3L Power Stroke Diesel 37 10-15-2011 08:45 PM
old injectors with rust and carbon 91dirtydiesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 42 02-18-2011 01:08 AM
New big ford truck owner Azfordman60 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 12-30-2009 07:17 PM
Tags
1952, 52, air, cover, decal, dodge, emblem, emblems, ford, heater, m1, magic, mercury, parts, pickup, ram, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
