Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
Fuel Leak on 2000 7.3
Old 12-14-2010, 06:53 PM
stemwill's Avatar
stemwill
stemwill is offline
I had fuel in the valley between the heads and thought I had solved the leak when I tightened the four Torx bolts on the drain on the filter housing. WRONG!!! Still leaking. Can I buy a new gasket for the valve or is it like normal: you have to buy the entire housing?
Old 12-14-2010, 06:56 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
orings on drain valve are a common leak
Gatordog
12-13-2015 12:44 PM
green_95
11-25-2015 04:45 PM
frizzen
09-06-2015 04:59 PM
dampink
06-09-2015 08:25 PM
staarma
04-28-2015 07:52 PM
Quick Reply: Fuel Leak on 2000 7.3
