no oil pressure at idle - Ford Truck Enthusiasts Forums
Old 12-22-2010, 11:09 AM
l-m tech l-m tech is offline
l-m tech is gaining momentum as a positive member of FTE.
Exclamation no oil pressure at idle
i have a customers vehicle in the shop that is complaining of a oil pressure gauge going to zero.diag.-checked for a missing/damaged stop drain valve inthe filter housing.checked base oil pressure regulator for stuck condithion.installed manual gauge,0 psi at idle,45 psi at 2500 rpm.i have heard of a plug in the back of the block blowing/coming out.can anyone lend a hand to if this issue is true.the truck started doing this instantly.has been running fine.no codes.oil is clean and full.no metal in the filter.thanks.
Old 12-22-2010, 11:13 AM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
If oil pressure is actually zero on the 6.0, the engine stops running.
Because oil pressure is needed to fire the injectors.
You probably got a bad sensor or bad wiring.
Do you have the IDS?
Old 12-22-2010, 11:30 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
The oil pressure switch is here: Page 25: Lubrication System . It's probably the switch itself gone bad OR the wiring connector. It's just a one wire grounded switch that powers the idiot needle in the dash. The gauge only takes 7.5 psi to put it in the "normal" range. FYI--the swith is the same as a 7.3 if you've got one. Connector is motorcraft # wpt439.
Old 12-22-2010, 12:23 PM
i have a actual manual gauge on it.have checked it with 2 diff. ones. it is the base oil pressure system that has the concern not the high pressure system for the injectors.
Old 12-22-2010, 12:47 PM
hubler13f's Avatar
hubler13f hubler13f is offline
hubler13f has a good reputation on FTE.hubler13f has a good reputation on FTE.
Deleted by poster: Information was irrelevant, misguiding and not well thought out.
Old 12-22-2010, 05:05 PM
any other takers?
Old 12-22-2010, 05:15 PM
If it's an 03 or 04 engine the HPOP has a ball plug in the pump that can blow out. Rethreading the hole for a pipe plug has worked. Sorry I misread the pressure you posted.
Old 12-22-2010, 05:23 PM
Quote:
Right --- I misread it too... didn't see it was a manual gauge.
Probably the plug... I don't have that problem on the 05...
Old 12-22-2010, 07:46 PM
vloney vloney is offline
vloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant future
Quote:
Originally Posted by l-m tech View Post
any other takers?
Do you have the OEM filter and oil cap on it?
Old 12-23-2010, 07:22 AM
has a wix 57312 tall filter.the truck has went 500 miles sence i put a oil and egr cooler on it with no problems.how would a missing plug in the hpop cause base oil pressure to be low.wouldnt it set a low icp pressure code.fixin to take a vacation ,first one in 20 years,havnt done anything else yet.will get back to it after the new year.
Old 12-23-2010, 07:29 AM
I've been finding the aftermarket filters with the replacement caps built on have a problem with the bottoms of the filter warping, not letting the valve at the bottom of the housing close all the way. That creates a "leak", if you will, not letting oil pressure build completely. You see the lack of pressure at idle mostly. You still get enough oil to fire the injectors, but not enough to build oil pressure at the guage. Replacing the filter and cap with OEM solved these issues.
Old 12-23-2010, 11:15 AM
69cj's Avatar
69cj 69cj is online now
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
I agree with Vloney. A/M filters have caused many problems with the 6.0. I can't guarantee that's your problem but I would absolutely start with a 20 dollar filter and that way your safe.
Old 12-28-2010, 09:01 PM
steve0484 steve0484 is offline
steve0484 is starting off with a positive reputation.
I Have Same problem, mine at start reads nothing with check gauge light on, if i throtle up up it works and check gauge light goes out.stays ok but once in a while. but up on strart up everytime cold or warm. Woundering where sensor is to replace
Old 12-29-2010, 04:20 AM
Switch and sensor are here: Page 25: Lubrication System
Old 12-29-2010, 09:19 AM
69cj's Avatar
Hey Tim, I thought you already said that in post #3?
High LPOP Pressure sunogbahay 1999 - 2003 7.3L Power Stroke Diesel 6 06-07-2016 09:45 AM
Somewhat low oil pressure. Bryishre 1999 - 2003 7.3L Power Stroke Diesel 5 02-22-2016 06:43 PM
HELP…Strange oil pressure behavior Mr-Pipeline Modular V10 (6.8l) 30 05-17-2010 10:13 PM
Low Oil PSI and HPOP Failure dieseldrivr 6.0L Power Stroke Diesel 3 12-09-2009 09:11 PM
Real Oil Pressure jimandmandy Oil & Lubrication 11 10-07-2003 11:46 AM
Tags
04, 60l, bad, f250, ford, lost, missing, oil, plugin, pressure, stop, switch, truck, turbo, wix, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
