Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Montana Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Montana Chapter Join Chapter , Leader: jredline1984
  #1 (permalink)
Old 12-22-2010, 01:43 AM
PstrokeN's Avatar
PstrokeN PstrokeN is offline
Garage is empty, add now
PstrokeN is starting off with a positive reputation.
smoke switch???
have any of you diesel boys ever done a smoke switch? i hear you take the green wire from the map sensor and splice a switch into it??
  #2 (permalink)
Old 12-23-2010, 12:23 AM
sledheadm7's Avatar
sledheadm7 sledheadm7 is offline
sledheadm7 is starting off with a positive reputation.
what truck is this for
__________________
02 F-250 7.3L 4x4 CC LB with 6637, and 4" turbo back exhaust,FRX,HPX, coolent filter,DP Tuner,Zoodad,AIH delete, AirDog150, T500 hpop, Autometer gauges, for now
  #3 (permalink)
Old 12-23-2010, 12:55 AM
PstrokeN's Avatar
smoke switch
my 99 psd i heard its the green wire off the map sensor but wasnt sure
__________________
97 F-250 auto with trans cooler and fan,3in DP straight piped, auto meter trans gauge in dash boost and egt in pillar,after market inner cooler,ball hitch in bed, 6637 mod,ccv mod,225/70/19.5s,315/75/17s,210,000
  #4 (permalink)
Old 12-23-2010, 08:38 PM
DasCheckers's Avatar
DasCheckers DasCheckers is offline
1997 Ford F-350
My Garage
DasCheckers has a good reputation on FTE.DasCheckers has a good reputation on FTE.
From what I know you have to have a tuner, and then buy a smoke switch for it. It increases fuel and decreases boost.
  #5 (permalink)
Old 12-23-2010, 10:34 PM
PstrokeN's Avatar
switch
stoney its me joey i have a chip juice with atittude
__________________
  #6 (permalink)
Old 12-23-2010, 11:38 PM
1997 Ford F-350
My Garage
Hey man I thought that might be yo bish ***.
Do you have 3 wires running to your map?
  #7 (permalink)
Old 12-23-2010, 11:58 PM
PstrokeN's Avatar
yeah three wires i heard u can slicew into te green one and i seen a guy do it on a 01 cummins with three wires off the edge chipp and he sliced the pink and black wire to a switch i have 2 blks and one green i sliced the green and powered blk to a swich i hit the check engine light comes on and it smokes a little more nothing crazy tho? these guys were talkin rollin coal lik a mother, then i hit the switch off and after a little cel goes away, but with it chipped it barely smokes on setting 5 and the low boost on 5
__________________
  #8 (permalink)
Old 12-24-2010, 11:00 AM
1997 Ford F-350
My Garage
From The Cummins Forum,
Quote:
Originally Posted by Mopar1973Man
"A - 5V+
B- Signal
C - GND
This 3 wires can be in in order from year to year. Especially if you replaced a MAP and got the adapter.
But you want to shutdown the signal lead going to the Edge Comp not the MAP lead to the ECM!
But MORE SMOKE mean LESS MPG. Unburnt fuel... "
Also a quote from Gale Banks @ Banks Racing,
Quote:
Originally Posted by Gale Banks
"Smoke is the negative legacy of diesel - it's just plain wrong. It's power you can see but not use" ~Gale Banks
  #9 (permalink)
Old 12-24-2010, 11:31 AM
PstrokeN's Avatar
ok i tink did it right then i put th 5v and singnal to a switch
__________________
  #10 (permalink)
Old 12-24-2010, 03:11 PM
1997 Ford F-350
My Garage
I've read a couple different things man, I think you did it right though. Have you tried unplugging the map completely? Just to test, not to leave off permanently haha.
  #11 (permalink)
Old 12-24-2010, 05:51 PM
PstrokeN's Avatar
switch
no i havnt unplugged it i will try that tonight and see what it does b/c i get more smoke then i did with out the switch but its not alooooot, and i thought i can throw her in 6th gear and lug her to get alot but no it doesnt smoke till thje turbo spools a little then at high rpm it wont smoke idk lol ill try unplugging it
__________________
  #12 (permalink)
Old 12-24-2010, 07:08 PM
PstrokeN's Avatar
i unplugged it and it smokes but it doest have the CEL like if i it the switch?
__________________
  #13 (permalink)
Old 12-24-2010, 08:27 PM
1997 Ford F-350
My Garage
Permanently unplugging the MAP isn't advised, but you might have the wires hooked up to the switch wrong or something.
The switch should dictate that there is no boost, therefore dumping excess fuel to the engine, creating more smoke!
  #14 (permalink)
Old 12-24-2010, 10:44 PM
PstrokeN's Avatar
well theres a tanish wire too wonder what that does?
__________________
Tags
64, 6th, 73, chip, comp, diesel, edge, ford, forum, geart, lugging, smoke, switch, truck, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
