7.3 low oil pressure
Old 12-22-2010, 12:28 PM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
Originally Posted by PaysonPSD
Nice info jetdoc.
I found 2 references to oil pressure in the service manual, but they both are at 3300 RPMS and could not find a reference for oil pressure
at idle. Could it be that 5-7 PSI at idle is not a big deal? But jetdoc's is better than twice that.
I don't even know what my oil pressure is at idle.
It sais 10 psi Robin, or am I looking at it wrong...
Old 12-22-2010, 12:35 PM
duck fan's Avatar
duck fan
duck fan is offline
Because racetruck
These guys are steering you in the right direction. We are starting to see a lot of LPOPs go bad above 200K. They are really easy to replace. Follow the link Payson gave you. Best place to get a replacement is here: Riffraff Diesel: Melling LPOP
Good luck! Hope this solves it.
Old 12-22-2010, 01:16 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
Thanks Frank. I friggin missed that. I better put on my glasses. Glad I posted it so someone could straighten me out. Now we all know.
Maybe 5-7 PSI isn't so bad after all and is an early warning sign that LPOP may soon need an R&R.
Originally Posted by ernesteugene
..."The minimum engine oil pressure specifications are 82.7 kPa (12 psi) at 700 rpm, 165.5 kPa (24 psi) at 1,200 rpm and 310.3 kPa (45 psi) at 1,800 rpm with the engine at operating temperature."...
And thank you Gene for this info. I am saving that for sure.
It's nice to see you around Gene.
Amazing what good info resulted from my post.
Old 12-22-2010, 02:02 PM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is online now
My first thought is a piston cooler oil jet fell out.
Old 12-22-2010, 03:08 PM
JJD's Avatar
JJD
JJD is offline
Thanks for all of your info, re reading all the posts everyone seems to be leaning to the LPOP. The service guy says in all his history he has never had an oil pump fix a low pressure problem. I'm going to have them check out the pressure regulator in the oil cooler, I guess thats the same thing that Kwikkordead mentioned if not let me know. Then I'm bringing the big guy home to replace the LPOP myself. Does the LPOP housing have any seals on it I should replace? I read something about a crank seal. I want to get everything I need before I start. Are there sponsors of this web site that I can order these things through? I would like to support them.
If you can think of anything else keep the info coming. I will post the out come on my end.
I do have to find the right fitting to screw into my sending unit port the MAC oil tester my buddy let me borrow has every fitting but the right one.
Thanks again this has been a wealth of information.
Old 12-22-2010, 03:15 PM
duck fan's Avatar
duck fan
duck fan is offline
Because racetruck
The LPOP comes ready to install. Look at my previous post in this thread. I posted the link.
Old 12-22-2010, 03:25 PM
bpdad's Avatar
bpdad
bpdad is offline
JJD,
You have come to the right place to get some informed and friendly help. The members and resources here are incredible.
I had the same issue with my 7.3 last summer and it turned out to be a bad bearing. I hope yours is something much simpler.
In addition to what others have already said I recommend that you:
1. change the oil and filter
2. while the filter is off check the check valve above the filter
3. while the drain plug is out use a light and a wire to check for any foreign objects in the bottom of your oil pan - You might find a piston cooling nozzle that has fallen out of position. Or if you are like me you might find pieces of destroyed bearings.
Keep us posted on your progress and good luck.
Old 12-23-2010, 11:25 PM
JJD's Avatar
JJD
JJD is offline
Good news oil pressure is up they found some debris holding open the pressure relief valve in the oil cooler. I'm going to cut open the oil filter with a wheel cutter and see if any major debris is in there, or if this was just a fluke thing. Thanks again for all your help ,I'm glad I found this web site.
Old 07-16-2013, 11:06 PM
fordnutharv's Avatar
fordnutharv
fordnutharv is offline
low oil preasure at idle 7.3
96 powerstroke
mine lost part of oil preasure regulator valve into oil pan.
it is located in oil cooler , the end with the filter, my oll preasure was 2 at idle
like to never found it. finally a ford truck parts man at parts counter recegnised missing piece
Old 07-16-2013, 11:10 PM
fordnutharv
oil pump
7.3 p0werstroke real simple change right behind harmonic ballancer ,remove it take out 4 bolts and walla
burnthelight88
01-25-2017 02:25 AM
SpringerPop
32
11-24-2011 02:05 AM
snelldawg
1999 to 2016 Super Duty
49
05-14-2010 09:41 PM
1997stroker
06-26-2007 05:38 AM
Quick Reply: 7.3 low oil pressure
