Ford fuel guage-GM tank/sending unit - Ford Truck Enthusiasts Forums
Old 12-21-2010, 08:01 PM
KenMcClelland65ss KenMcClelland65ss is offline
KenMcClelland65ss is starting off with a positive reputation.
I am trying to hook up my fuel guage. I relocated the fuel tank from behind the seat to the frame using a GM tank. When i hook up the GM sending unit to the guage nothing. When i hook up the original sending unit and move the lever the guage works. Is the Ford fuel guage and GM sending unit compatible?
Old 12-21-2010, 08:33 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Nope, you are outta luck as each reads opposite ends of the OHM spectrum. 0 to 90 vs 150 to 100.
Only cure is to place the correct ford sender in the tank or go with aftermarket Gauge and sender.
Garbz
Old 12-22-2010, 12:31 AM
dman2008's Avatar
dman2008 dman2008 is online now
dman2008 is starting off with a positive reputation.
Too funny I just fixed that issue on the weekend on my truck. I installed dolphin gauges in my truck and it is set up for a gm sending unit, 0-90ohms which they give you with the gauges. My tank is a midship from a 75 f150 and it was reading backwards with the new gauges, so when I measure the ford unit out of the tank i was reading about 70 on empty and 12 or so on full approx quick readings. Anyhow I took the resistor off of the gm sending unti supplied with my gauges and welded it to my ford sending and now its all good. Hope this helps you understand what you need to do, maybe see if you can install you sending unit resistor onto you gm unit.
gas tank erik68 1973 - 1979 F-100 & Larger F-Series Trucks 15 04-24-2014 08:59 PM
fuel guage and dash lights dont work? erik68 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-13-2014 10:36 AM
Transmission temp sending unit priv8pilot 1999 - 2003 7.3L Power Stroke Diesel 5 07-20-2006 11:36 AM
Fuel Gauge doesn't work rhipps6525 Explorer, Sport Trac, Mountaineer & Aviator 3 10-01-2004 07:09 PM
Gas gauge problem gcfisher75 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-11-2002 05:33 AM
Tags
ford, fuel, gauge, gm, sending, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
