New Drive-shaft/yoke dynamometer. Need your help!
Old 12-21-2010, 06:49 PM
Dr.Mike's Avatar
Dr.Mike
Dr.Mike is offline
Hi all.
Not 100% sure if this is the right section for this. But, here goes
I have just developed a new drive-shaft torque sensor/dynamometer. I am looking to adapt it to Ford vehicles. Currently, it is up and running on a Chevy 2500HD ( yeah yeah... I know ). Ford seems to be more into performane trucks than GM.
It currently works with the Innovate Motorsports LogWorks software. And the LC-1 and the rest of their MTS devices. It is a real strain-gage based torsional force sensor, mounted to the slip-yoke. No accelerometers, timers, GPS, etc.
It is similar to the Land-and-Sea "On-board Dynamometer" see: http://www.land-and-sea.com/rotary-s...shaft-dyno.htm
Here it is, installed in my 2002 2500HD 4x4 ( yeah yeah...I know )
So far, testing has gone better than expected. Even with the big 32-spline 1410 yoke on my HD, I can easily resolve less than +/- 1lb-ft of torque ( out of a full scale of +/- 4500 lb-ft ) and +/- 1hp. Although, the weather has put a temporary hold on further testing.
What I am looking for is the info that I need to make installation kits for the various Ford RWD applications. Specifically, the slip-yoke dimensions and the tail-shaft housing dimensions that I need to mount the field coil.
I am trying to get this out to the public for less than $1500.00 ( vs. the $5000-$7000 that Land and Sea wants ).
Any help, dimensions-wise, is appreciated
Thanks, all<!-- google_ad_section_end -->
Old 12-23-2010, 02:57 PM
ReAX's Avatar
ReAX
ReAX is offline
Very cool idea, I don't have the specs on hand, but here's a bump.
Old 12-23-2010, 07:46 PM
Dr.Mike's Avatar
Dr.Mike
Dr.Mike is offline
Thanks
Even a list of the most popular models for tuning/mods would be helpful. Then I could go down to the dealership with a set of calipers and try to sneak into the service area :P
Old 12-24-2010, 08:29 AM
ReAX's Avatar
ReAX
ReAX is offline
I think you just have two transmissions to worry about. The mod motors have the 4r100 for the early trucks and 5r110 for the newer trucks. I'm not sure but I think even the high end mustangs will run one of those two, I don't think the small trans can take the supercharger.
For models, I'd look at Lightnings and f250 diesel as they are both factory supercharged and may have a bigger performance following. Then the diesel trans should be very close to the gas f150 and up in dimensions.
Old 12-24-2010, 08:57 PM
Dr.Mike's Avatar
Dr.Mike
Dr.Mike is offline
Thanks for the tip
Old 10-26-2011, 06:40 AM
Dr.Mike's Avatar
Dr.Mike
Dr.Mike is offline
And.. I can finally talk again
AEM ( who took over the Dino project from me, after all of the hard work was done ) has finally released the drive-shaft dyno kit.
AEM’s Dyno-Shaft Gives You HP and TQ Numbers on the Go - StangTV.com
A few changes ( like the controller PCB integrated into the coil housing, etc. ) But, it turned out nice
Thread necromancy rocks !
Macrobb
21
03-14-2021 09:49 AM
Bently_Coop
1999 to 2016 Super Duty
25
07-23-2017 08:44 AM
AdPock
2017+ Super Duty
04-15-2016 10:47 AM
Thoroughbred Diesel
Events & Happenings
10-10-2014 02:22 PM
TMI
108
01-10-2007 09:50 AM
Quick Reply: New Drive-shaft/yoke dynamometer. Need your help!
