New Drive-shaft/yoke dynamometer. Need your help! - Ford Truck Enthusiasts Forums
Old 12-21-2010, 07:49 PM
Dr.Mike Dr.Mike is offline
Dr.Mike is starting off with a positive reputation.
Hi all.
Not 100% sure if this is the right section for this. But, here goes
I have just developed a new drive-shaft torque sensor/dynamometer. I am looking to adapt it to Ford vehicles. Currently, it is up and running on a Chevy 2500HD ( yeah yeah... I know ). Ford seems to be more into performane trucks than GM.
It currently works with the Innovate Motorsports LogWorks software. And the LC-1 and the rest of their MTS devices. It is a real strain-gage based torsional force sensor, mounted to the slip-yoke. No accelerometers, timers, GPS, etc.
It is similar to the Land-and-Sea "On-board Dynamometer" see: http://www.land-and-sea.com/rotary-s...shaft-dyno.htm
Here it is, installed in my 2002 2500HD 4x4 ( yeah yeah...I know )
So far, testing has gone better than expected. Even with the big 32-spline 1410 yoke on my HD, I can easily resolve less than +/- 1lb-ft of torque ( out of a full scale of +/- 4500 lb-ft ) and +/- 1hp. Although, the weather has put a temporary hold on further testing.
What I am looking for is the info that I need to make installation kits for the various Ford RWD applications. Specifically, the slip-yoke dimensions and the tail-shaft housing dimensions that I need to mount the field coil.
I am trying to get this out to the public for less than $1500.00 ( vs. the $5000-$7000 that Land and Sea wants ).
Any help, dimensions-wise, is appreciated
Thanks, all<!-- google_ad_section_end -->
Old 12-23-2010, 03:57 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
Very cool idea, I don't have the specs on hand, but here's a bump.
Old 12-23-2010, 08:46 PM
Thanks
Even a list of the most popular models for tuning/mods would be helpful. Then I could go down to the dealership with a set of calipers and try to sneak into the service area :P
Old 12-24-2010, 09:29 AM
ReAX's Avatar
I think you just have two transmissions to worry about. The mod motors have the 4r100 for the early trucks and 5r110 for the newer trucks. I'm not sure but I think even the high end mustangs will run one of those two, I don't think the small trans can take the supercharger.
For models, I'd look at Lightnings and f250 diesel as they are both factory supercharged and may have a bigger performance following. Then the diesel trans should be very close to the gas f150 and up in dimensions.
Old 12-24-2010, 09:57 PM
Thanks for the tip
Old 10-26-2011, 07:40 AM
And.. I can finally talk again
AEM ( who took over the Dino project from me, after all of the hard work was done ) has finally released the drive-shaft dyno kit.
AEM’s Dyno-Shaft Gives You HP and TQ Numbers on the Go - StangTV.com
A few changes ( like the controller PCB integrated into the coil housing, etc. ) But, it turned out nice
Thread necromancy rocks !
Virtual Towing: New Super Duty Too Tough for Old Dyno AdPock 2017 Super Duty 6 04-15-2016 11:47 AM
Rob's Dyno Day - 248 HP IDI! (Hunting 4 Horsepower) Macrobb Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 09-13-2015 10:28 PM
Eaton M90 supercharger on Ranger 4.0 sohc rubydist Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 30 03-18-2013 09:13 PM
400 engine build up for Brad TMI 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 8 09-09-2008 11:37 PM
Dan Lee 434 on the dyno TMI 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 108 01-10-2007 10:50 AM
Tags
1996, board, build, citys, drive, driveshaft, dynamometer, dyno, explorer, ford, sale, shaft, shafts, sport, truck, wuad, yoke, yolk
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
