2001 F150 4x4 4.6 Won't shift into 3rd or OD - Ford Truck Enthusiasts Forums
Old 12-21-2010, 07:35 PM
iowabowhunter iowabowhunter is offline
iowabowhunter is starting off with a positive reputation.
Hi guys
I have a 2001 F150 4x4 4.6 that Won't shift into 3rd or OD. No warning lights on the dash, and 1, 2 , and Reverse are fine. It has neutraled out on me once, but normally just stays in 2nd. I purchsed the truck this way, and was going to replace the tranny. But after doing some reading it appears this may be electronic. Any ideas??
Thanks
Bob
Old 12-23-2010, 03:33 PM
usafstud usafstud is offline
usafstud is starting off with a positive reputation.
What speed and rpm u running?
Escape shift problem pabear89 Escape & Escape Hybrid 11 07-08-2013 07:16 PM
2001 F150 4R70W 4X4 transmission doesn't shift from 3rd to OD Albert Martinez 1997 - 2003 F150 6 03-18-2012 09:22 AM
97 F150 4X4 4.6L E4OD won't move izaquad Clutch, Transmission, Differential, Axle & Transfer Case 4 11-14-2010 10:31 PM
98' F150 won't down shift Merculous 1997 - 2003 F150 2 05-21-2006 07:17 AM
AOD won't shift to 3rd or OD, stays in second. Torque1st Clutch, Transmission, Differential, Axle & Transfer Case 6 09-17-2002 10:28 PM
Tags
01, 1996, 1999, 2001, 3rd, 97, band, f150, f350, ford, motero, navigator, shift, transmission, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
