1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
x springs/plow prep??
Old 12-21-2010, 05:06 PM
pkenn7's Avatar
pkenn7
pkenn7 is offline
i thought i had x springs on my 02 f250 v10 which i believe are rated 6000lbs?
but then i saw this on the ford website...what gives?? how can i tell if i have x springs? my gawr says 5200 lbs front, but my spring code is "XA"and my truck sits higher for sure.
"• Snowplow Package, includes:
—Highest Front GAWR’s (5200 lb. for F-250-350; 6000 lb. for F-450-550)"
Old 12-21-2010, 05:56 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
99-04 f-250 and 350 snow plow springs are 6000lbs. just check your door sill sticker and look for the front groww weight. if its 6k you have them if its not then you dont
Old 12-21-2010, 06:05 PM
pkenn7's Avatar
pkenn7
pkenn7 is offline
well thats the odd thing...front gawr is 5200lbs according to the door sticker, but the spring code is "xa"? and i think xsprings are 6k and my truck is def higher in the front than trucks that dont have it.
Old 12-21-2010, 06:31 PM
2002 F350V10's Avatar
2002 F350V10
2002 F350V10 is offline
This is taken from another thread on the forum.
a 2004 F SuperDuty:
Rear Springs — F-Series
B — 3C34-5560-L
C — 3C34-5A975-D
D — 3C34-5A975-G
E — 3C34-5A975-K
J — 3C34-5A975-J
M — 3C34-5A975-E
N — 3C34-5A975-F
P — 3C34-5A975-C
S — 3C34-5A975-C
2003 manual
Front Springs — F-Series
B — F81A-5310-EA
C — F81A-5310-EA
D — F81A-5310-EA
E — F81A-5310-EA
F — F81A-5310-FA
G — F81A-5310-GA
H — F81A-5310-HA
I — F81A-5310-RA
J — F81A-5310-JA
K — F81A-5310-KA
R — 2C34-5310-AAB, 3,600 lb.
S — 2C34-5310-AAB, 4,000 lb.
T — 2C34-5310-ABB, 4,400 lb.
U — 2C34-5310-ACB, 4,800 lb.
V — 2C34-5310-ADB, 5,200 lb.
W — 2C34-5310-AEA, 5,600 lb.
X — 2C34-5310-AFA, 6,000 lb.
Y — 2C34-5310-VA
Z — 2C34-5310-WA
B — F81A-5310-EA
C — F81A-5310-EA D — F81A-5310-EA
E — F81A-5310-EA
F — F81A-5310-FA
G — F81A-5310-GA
H — F81A-5310-HA
I — F81A-5310-RA
J — F81A-5310-JA
K — F81A-5310-KA
Y — 2C34-5310-VA
Z — 2C34-5310-WA
Front Springs — Excursion
B — YC35-5310-ABC
C — YC35-5310-ACC
D — YC35-5310-ADA
G — YC35-5310-GA
H — YC35-5310-HA
S — YC35-5310-SA
B — 1C34-5560-CB also 3C3Z-5560-CB
C — 1C35-5560-DB
D — YC35-5560-EA
M — YC35-5A975-AA
N — YC35-5A975-BA
S- 3C3Z-5560-CA one you should get for EX spring swaps.
Rear Springs — Excursion
V code fronts..2C3Z-5310-HA get for Ex spring swap.
A — YC35-5560-A
Rear SD 30mm bar.. F81Z-5A772-AA
2007 F-Super Duty 250-550 Workshop Manual
SECTION 100-01: Identification Codes
DESCRIPTION AND OPERATION
Vehicle Certification (VC) Label
Springs
Springs codes are listed (on the VC label) as a 2-part code. The first character listed is for the front springs. The second code listed is for the rear springs. Auxiliary rear springs may also be listed.
Front Springs
AA — 5C34-5310-AMD, 7,000 lb
BB — 5C34-5310-ALD, 6,500 lb
CC — F81A-5310-AHD, 6,000 lb
DD — F81A-5310-AGD, 5,600 lb
EE — F81A-5310-EA, coil
FF — F81A-5310-FA, coil
GG — F81A-5310-GA, coil
HH — F81A-5310-HA, coil
II — F81A-5310-RA, coil
JJ — F81A-5310-SA, coil
KK — F81A-5310-TA, coil
TT — F81A-5310-AFD, 5,200 lb
VV — F81A-5310-AED, 4,800 lb
YY — F81A-5310-UA, coil
ZZ — 2C34-5310-WA, coil
Rear Springs
BB — 5A975, leaf
CC — 5A975, leaf
DD — 5A975, leaf
FF — 5560, leaf
HH — 5A975, leaf
JJ — 5A975, leaf KK — 5A975, leaf
NN — 5A975, leaf
It may be useful. You will have to figure it out.
Old 12-21-2010, 06:36 PM
2002 F350V10
The numbers are stamped on the springs (or at least mine were) for some oem replacement springs I had bought. I purchased new take offs which were stamped on the front leaf spring 2C34-5310-ADB, which shows they are V springs , 5,200 lb.
Dronepilot
2017+ Super Duty
60
05-11-2018 09:54 PM
backtrack2015
Fifth Wheel & Gooseneck RV Towing
30
10-13-2017 02:39 PM
nxtdiesel
2017+ Super Duty
02-26-2017 02:36 PM
powerstroker100
11-25-2015 05:58 PM
RickBraden
24
03-19-2012 12:33 PM
Quick Reply: x springs/plow prep??
