2000 Ex - no power windows or dome lights, fuse ok
Old 12-21-2010, 01:18 PM
Part-Timer's Avatar
Part-Timer
Part-Timer is offline
Hi everyone,
Just had a problem come up with my 2000 Ex this morning: No power windows, dome lights, map lights, vanity mirror lights, power mirrors, etc. I checked fuse # 14 and it looked good. I tried a new fuse anyway and no change. I also checked all of the other fuses in the interior box and fuse #601 in the engine bay - everything looked ok.
I'm at work so I couldn't check to see if fuse #14 was actually getting any power to it, but this will be the next thing I will look into when I get home.
In the meantime, any suggestions on where else I might check for the problem would be greatly appreciated.
Thanks & regards,
Brian
Old 12-21-2010, 01:41 PM
fgials's Avatar
fgials
fgials is offline
Mine did that while i was changing a bulb and it sparked. I tried everything and took it to my mechanic next day. They couldn't find any blown fuse either so they scanned and reset and that fixed it.
Old 12-21-2010, 02:06 PM
Part-Timer's Avatar
Part-Timer
Thanks fgials.
After a bit more looking at the manual, I figured that the problem could be related to a bad battery saving relay. A quick run down the street to the local Ford parts counter and with a new relay in hand, I had the problem fixed. An easy repair for once!
Thanks again and Merry Christmas!
Brian
bonshates
1999 to 2016 Super Duty
12-02-2020 04:28 AM
pmcortez
01-30-2017 05:05 PM
mrc00l88
12-11-2016 07:33 PM
AmericanPrideUSA
06-16-2015 07:18 AM
KentWilkens
10-05-2011 02:33 PM
Quick Reply: 2000 Ex - no power windows or dome lights, fuse ok
