Aligment Specifications - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-21-2010, 08:13 AM
99F-350CrewCab's Avatar
99F-350CrewCab 99F-350CrewCab is offline
99F-350CrewCab is gaining momentum as a positive member of FTE.99F-350CrewCab is gaining momentum as a positive member of FTE.
Does anyone have the alignment specs for a 99 f-350 4x4 crew cab SRW? I have an old laser alignment setup and I was going to check it, but I'm not sure what the toe should be. Or does any one have any recommended settings that may be better then the factory settings? Thanks in advance.
Old 12-21-2010, 08:49 AM
Darrenigel Darrenigel is offline
Darrenigel is starting off with a positive reputation.
<TABLE border=1 cellSpacing=0 cellPadding=3><TBODY><TR><TD vAlign=top colSpan=4 align=left>Alignment Specifications F-250 and F-350, 4x4</TD></TR><TR><TD vAlign=top align=left>Caster @ Curb Ride Height</TD><TD vAlign=top align=middle>3.5 2</TD><TD vAlign=top align=middle>3.5 2</TD><TD vAlign=top align=middle>0 1</TD></TR><TR><TD vAlign=top align=left>Camber @ Curb Ride Height</TD><TD vAlign=top align=middle>0.25 1</TD><TD vAlign=top align=middle>0.25 1</TD><TD vAlign=top align=middle>0 1</TD></TR><TR><TD vAlign=top align=left>Toe @ Curb Ride Height (Positive Value Is Toe-In, Negative Value Is Toe-Out)</TD><TD vAlign=top align=middle></TD><TD vAlign=top align=middle></TD><TD vAlign=top align=middle>0.03 0.25</TD></TR><TR><TD vAlign=top align=left>Steering Axis Inclination (SAI) @ Full Load</TD><TD vAlign=top align=middle></TD><TD vAlign=top align=middle></TD><TD vAlign=top align=middle>8.5</TD></TR><TR><TD vAlign=top align=left>Included Angle @ Full Load</TD><TD vAlign=top align=middle></TD><TD vAlign=top align=middle></TD><TD vAlign=top align=middle>8.5</TD></TR></TBODY></TABLE>
Old 12-21-2010, 11:02 AM
That's perfect, Thanks!
Old 08-07-2014, 09:56 AM
Mystic_Cobra's Avatar
Mystic_Cobra Mystic_Cobra is offline
Mystic_Cobra is starting off with a positive reputation.
2009 SRW 4x4
Dealer image shows 2008-2011 F350 4x4 SRW being the same.
My local dealer has my truck and is doing an alignment. It's never been done in 85000 miles. They are replacing the steering box and recommended an alignment. Since, it had never been done, I decided to do it.
After checking, he says they need me to buy a shim kit in order to get the alignment into specs. The truck is completely stock. Says the shim kit is $80 PLUS installation.
He sent me a pic of the current alignment:
FRONT
CAMBER: L 0.4 R 0.2 * in the green range
CASTER: L 4.1 R 3.9 * both in red as alignment range is up to 3.9 deg
TOE: L 0.17 R 0.19 * left is green and right is red as range is up to .18 deg
All values positive.
Is already charging me $180 for the alignment which I think is ridiculous. Why would a stock engine need a shim kit to align it?
F350 leveling question Mcrafty1 1999 to 2016 Super Duty 3 07-23-2015 09:32 AM
Wheel alignment Revhed Australia Chapter 3 05-12-2015 06:10 AM
Need alignment, but axles bent? Eddillard79 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 12-14-2014 09:50 AM
Driveway Alignment Spktyr 1987 - 1996 F150 & Larger F-Series Trucks 11 09-22-2014 09:48 AM
Alignment Specs loveF350trucks 1987 - 1996 F150 & Larger F-Series Trucks 4 03-21-2012 11:00 AM
Tags
aligment, ford, specifications, specs, superduty, toein, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
