How many AMPS do the fuel pumps use? Is 7 AMPS too much?
on
Hi everybody,
Does anyone know how many amps the fuel pump is using?
I took a reading of 7 amps at the red wire of the fuel pump relay, is that too much?
If it is can you suggest where I can look for the problem? Both fuel pumps have been replaced.
Thanking you all in advance
on
on
First of all I think maybe you have been looking at the power relay and not the fuel pump relay.
In this case the red wire from the power relay supplies all of the solenoids and the fuel pump relay. So 7 amps for this wire would be OK.
Also I do not know what you are working on.
What year is it?
What transmission?
What engine do you have?
Is this a van or a RV?
If it is a RV what class is it (A, B or C)?
What year is it?
What transmission?
7 amps is not unusual -- that is less than 100w, which is not much power when it is running and moving fuel.
The critical thing --- the pump shuts off once max. pressure is reached and is not pulling 7amp all the time --- resulting in a much lower than 100% duty cycle.
It is constantly cycling on and off and that is normal.
The pump does not shut off, it runs all the time.
Hmmm... well.. take your word for the red wire it since my gasser is not in service and I haven't looked at it for a while.
The OP question is about power draw for a fuel pump... and 7 amps is not excessive.
This link below shows the power draw for a Honda Passport --- 9.4A peak, 5A average for a much smaller engine.
http://autolabscopediagnostics.com/fuelpump.htm
So 7 amp is not out of line at all.
I will have to pull the specs of the gasser pump --- but typically all commonly used fuel pumps will stop once "max pressure is reached --- it may be cycling (as shown in the above link), to me that is a shutoff.
My diesel fuel pump does shut off once it "pressurizes".
Fuel Pump Current Draw
Here are some actual traces of what current a fuel pump draws on a range of vehicles --- too bad the closest I can come to a 5.4 Ford is a 5.7 Chevy:
Fuel Pump Waveforms
Note the waveforms (up and down) that is the pump cycling on and off.
It may not appear to you that the pump is cycling on and off, but to an oscilloscope, it is obvious.
Fuel Pump Waveforms
I can't speak to the wire --- as my E is decommissioned.
But the amp draw... 7amps is not too much for a fuel pump pushing fuel for a 5.4
The question is, what is the 7amps doing going through that wire?
What is its function?
Or another question... how did he measure 7amps for that wire?
If he used a clamp on meter, it could be measuring the other circuit.
