What years have the Spark Plug blow out problems? - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 12-20-2010, 06:57 PM
scubydo scubydo is offline
scubydo is starting off with a positive reputation.
Sorry, I've searched, and haven't been able to find the answer. Anybody have any idea what years have the most trouble. Could you guys that had the problem respond with the year. Thanks.
I have an 03 5.4, and just wondered if I need to be packing parts.
Old 12-20-2010, 10:01 PM
97ExpGuy 97ExpGuy is offline
97ExpGuy is gaining momentum as a positive member of FTE.
97 - 02 2v 5.4 engines. Since you have an 03 model, you should have the revised heads that have more threads in the cylinder head. However, your not out of the water yet as the gen 2 Expys with the 3v heads had the two-part spark plug that is infamous for cracking upon removal due to a carbon build up on the threads. There is a special tool for aiding in removing broken spark plugs.
Read here:
http://www.f150online.com/forums/v8-...l-article.html
Ford Spark Plug Removal Tool - Picture of Ford's Bad Design | Denlors Auto Blog
Old 12-20-2010, 10:14 PM
Icefan71 Icefan71 is offline
Icefan71 has a good reputation on FTE.Icefan71 has a good reputation on FTE.
98 5.4 - I had a blowout on the passenger side 3rd back. Had to have it helicoiled a few months after a sparg plug change.
Old 12-21-2010, 03:25 PM
Londart's Avatar
Londart Londart is offline
Londart is starting off with a positive reputation.
I'm gonna need to do plugs on my 00 expy 5.4 eventually...dunno when they were done last and it's got roughly 150,000 on it and starting to get worse gas mileage than usual....any recommendations to avoid them blowing out or breaking off...any tips on making a lil easier job
Old 12-21-2010, 04:46 PM
hodges710's Avatar
hodges710 hodges710 is offline
hodges710 is starting off with a positive reputation.
Just as the other two said, it was mainly with the heads that had the plugs with the fewer threads. Thankfully on my 98 4.6 with 174,000 I have no problems for I have the 8 threaded plugs.
Old 12-21-2010, 09:05 PM
Mark T-TB's Avatar
Mark T-TB Mark T-TB is offline
Mark T-TB is starting off with a positive reputation.
the 03 does not have the 3V heads, that didn't start in the Expys until 05 (I think). My 04 w/5.4 still has the 2V heads.
Old 12-22-2010, 01:00 PM
theroyz71 theroyz71 is offline
theroyz71 is starting off with a positive reputation.
Quote:
I also have a 00 Expy 5.4L with 151K miles on it. I just got it and I have no idea when the plugs were last changed. Haven't checked the mileage yet.
Old 01-01-2011, 09:11 AM
F16Driver F16Driver is offline
F16Driver is starting off with a positive reputation.
I had one blow on the passenger side while towing a car trailer with a small 3500lb car on board. Pretty scary when it happens.
O2 Expedition EB with 5.4. At the time it had about 130K miles. That was about a year ago. I dont trust it for towing now just because I wonder if it will happen again.
Recall..... okgearhead 2009 - 2014 F150 6 07-11-2016 07:24 PM
truck shopping....need advice please cjben 1997 - 2003 F150 8 09-30-2015 05:07 AM
Last year of 302? and "good" trans tesserra Explorer, Sport Trac, Mountaineer & Aviator 11 07-12-2011 08:35 AM
Whats the best year for the 4.0 grease monkey Ranger & B-Series 7 12-19-2004 11:13 AM
front end question ranger240 1967 - 1972 F-100 & Larger F-Series Trucks 12 11-16-2003 08:15 AM
Tags
blow, f150, ford, models, navigator, plug, plugs, problem, problems, spark, threads, truck, trucks, v8, years
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
