1975 Ford Crew Cab Build - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 04-15-2014, 06:52 PM
DieselMike76 DieselMike76 is offline
DieselMike76 is starting off with a positive reputation.
For whatever reason I ended up tearing into the motor.
The PO said the Dodge Cummins has been wrecked. It was missing a few parts from the front FEAD so just for piece of mind i tore it apart to see if it was ok.
At 240k it had some minor wear. Head gasket had worn into block so off it went to machine shop for some massaging. Piston's were ok. So i decided to re-ring and while i was at it put new main bearings in also.
One thing led to another and suddenly there's a Hamilton Cam going in this thing.
Added ARP head studs while I was at it. So pretty...
  #32
Old 04-15-2014, 07:01 PM
This being my first engine rebuild my wife took this picture as she found it funny that I was so nervous I wanted to puke putting the head on.
Oh well got it on and torqued those ARP's down.
  #33
Old 04-15-2014, 07:07 PM
After taking this thing in and out probably 20 times here it is in its new home
With accessories
Super Bee turbo, DDP Injectors and delivery valves, standard P-Pump mods
  #34
Old 05-03-2014, 05:23 PM
crazed87bronco's Avatar
crazed87bronco crazed87bronco is online now
crazed87bronco is gaining momentum as a positive member of FTE.
Great looking engine. I already know the same thing will happen once I get into resealing mine. One thing after the next before you know it full rebuild.
The College/University Budget Build Thread Aaron-71 1973 - 1979 F-100 & Larger F-Series Trucks 235 08-02-2016 01:41 PM
My wiring nightmare... could use some help Aaron-71 1973 - 1979 F-100 & Larger F-Series Trucks 27 07-02-2015 03:53 PM
Project Frankenstein-'75 Ford Crew Cummins DieselMike76 1973 - 1979 F-100 & Larger F-Series Trucks 38 03-12-2015 10:39 PM
1975 Ford Crew Cab Build DieselMike76 Paint & Bodywork 20 04-15-2014 11:38 PM
Ford Emblem Failure........ jh225 6.7L Power Stroke Diesel 45 03-11-2014 11:38 AM
Tags
12v, 1975, build, cab, crew, cummins, diesel, f250, ford, mississippi, parts, pictures, special, swap, tow, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
