Dana 70u Rear Axle
Dana 70u Rear Axle
Category: Drivetrain
Price: $200
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Fit, S2000, CL, TL & Vigor
Item Condition: MA
Engine: Part suitable for gas truck, Part suitable for diesel truck
Dana 70u rear axle pulled from a daily-running F350.
It should bolt into any F350 cab and chassis with a 34" wide frame. Spring pads are 2.25" wide, and are 40.5" apart on center. Backing plates measure 48" apart. Wheel Mounting Surface (WMS) measures 65". Standard Ford 8 x 6.5" bolt pattern. 3.55 gears, open differential. All brake lines are still there and in good shape, even the brake hose is in good shape...truly ready to bolt up and go, works perfectly. Swapped out of a work truck because I intalled another axle that I rebuilt out of the truck and swapped in. Identified as a Dana 70u due to the smooth diff. case.
Just needs to be pressure washed and hit with some spray paint to look good!
