You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Does anyone have any tips or tricks on the removal of the fuel pump. I have it all disconnected according to Autozone website and the famous "Sams" thread on fuel pump replacement. I cannot get the fuel pump lifted out of the crankcase. I can wiggle it but not twist it. Any ideas?
Humm, I'm trying to think if there were any tricks when I did mine... As long as you disconnected the banjo bolt, and the two hold down bolts, there shouldn't be anything else holding it. IIRC, Mine was a PITA to get out of there also, took some patience and alot of beer.
You also might want to consider just getting it loose, then crank the engine over with a ratchet untill you see the pump lift up just a bit (cam will be pushing up on the tappet on the bottom of the pump) so if the tappet does fall, it won't disappear...
Robb
Also dont forget the blue fuel line in the front, and be very carefully because the pump could be broken
Thanks I just got it out. I noticed the tappet broke off. Can I get a new tappet becasue the pump works and looks new I just had a leak around it and was told to replace the seal around the bottom of the pump. As for the tappet, I havent got it out yet but IF it dropped way down in there does this mean bad things??? thanks for the photo.
DOH! You Don't want to hear what I am about say but....What I would do at this point is drain the oil and drag a heavy magnet around the bottom of the pan. HOPEFULLY you will find the tappet. Then drag that ba$dart offf to the side and leave the magnet in place....forever. If you can not find it I would SLOWLY turn the engine BY HAND back and forth (don't force nothen) back and forth till it drops and proceed with the original plan.
goodluck and let us know
__________________ Ian, 1 each (That's my nomenclature so don't wear it out) 97 F350 7.3L Auto 4WD Crew Cab 230K (Cali model bummer). MODS: HOOOOGA! horn, 6637, Service/Utility bed, 3" DP, Testing that Cat, 120v IDM. US ARMY OAS, OJE-IFOR, SFOR,2,5, OJG-KFOR, OIF, OEF. To ALL that have served, THANK YOU!
You are welcome, but that are not good news (that you havent got it out) Can you see the tapet in the hole where the pump goes?.
this time last year i posted a thread saying how i droped my lifter into the pan aswell. i let it be for a night then went back to work the next day. i rotaed the engine untill the lifter fell in to the pan, it can only fall onto the crank . one tooth at a time on the flywheel will help. i have a big magnet and asmall one next too it to keep it in place but to be honest. its not going to move at all, the sump is very deep and it couldnt possibly be picked up by movement.
I just got the new pump...and as for the tappet WELL its still in teh crank case hole...still not sure on how to get it out now. It seems like it craked from the old pump and stayed in there. AS for the fuel pump lifter...I just hope it hasent fallen into the crankcase.
I have not had the opportunity to replace my fuel pump (yet) But would a super strong *** magnet be able to attach to the broken tappet and pull it up from it's resting place?
You would think that turning the engine over by hand would push it up enough to get some vise grips on it. I'd be real tempted to crank it myself and just send it flying as long as the plunger hasn't fallen in.
I think the bolt on the dampner is a metric but a 15/16 socket fits. That's what I use to turn it over, that and a breaker bar.
__________________ Darin I BLEED BLUE 76F250 66 fairlane dragcar514
1997 F250 HD 7.3,3.55-4.10 swap done,156k,140VIDM,HPX, 3-4"tymar w 4"straight pipe,ccv mod, S366 turbo, DIY 6637, elec. fuel,rosewood stage ones,php tunes,T500 HPOP,180 tstat,6.0 fan,6.0IC,trucool,coolant filter,scan gauge,lots of other gauges,racer x valve body and triple disc billet converter, upgraded trans, F550 leaf springs,mean green alternator and starter,SD dual tensioner upgrade, cold ac mod
