2003 6.0 problems - Ford Truck Enthusiasts Forums
2003 6.0 problems
Old 12-20-2010, 12:52 AM
JerryG008 JerryG008 is offline
JerryG008 is starting off with a positive reputation.
2003 6.0 problems
I own a Power Stroke 6.0 and it has a bully dog tripple power pup on it that i got from a friend and the chip is throwing five codes and it wont run it started loaping and then died i cant figure out what is wrong with it. the codes were P0113 IAT High input, P0403, P0603 ICM Kam (DL), U0630, and P1000 OBD reset (DL). Can anyone help me out thanks.
Old 12-20-2010, 09:21 AM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is online now
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
Welcome to FTE JerryG008 Did you buy this truck from a friend with the programmer or did you buy the programmer and install it on your truck? I would remove the programmer to eliminate any influence.
Old 12-20-2010, 10:18 AM
I bought the truck at an auction and the chip did not come with the truck. I also took the chip off the truck and tried to get it to start and it still would not start so i put the chip back on it to read the trouble codes and thats the codes that it threw. thanks for the replies.
Old 12-20-2010, 06:54 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Quote:
P0113 and P0403 are circuit short to ground codes from what I read, so I would check the MAF and EGR part of the wiring harness around the drivers side front of the valve cover to start with. Possible you have a chaffing issue.
Old 12-20-2010, 07:10 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
p0113 is iat1 make sure its pluged in correctly
p0603 is kam reset dont worry about this code
p0403 remove the egr vlave and check for it being stuck open
u0603 most likly caused by the bully dog
p1000 dont worry about this either. thats a pass without all moniters completed yet
Old 12-20-2010, 09:06 PM
havns3's Avatar
havns3 havns3 is offline
havns3 is starting off with a positive reputation.
cheezit, you sir are "da bomb"
Old 12-20-2010, 09:25 PM
cheezit's Avatar
Quote:
ask anyone thats ever talked to me in person I assure you im much over rated ....
and humble
Brown Betty - Chase/Tow Rig Build drewbee88 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-15-2016 07:09 PM
Dana 60 Carrier Spider Gear Question Zazoos 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-12-2015 12:12 AM
Leaf Spring Bushing Removal Trick Zazoos 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-04-2015 08:40 PM
Dana 44 Help Needed with Pics Zazoos 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-17-2015 07:36 AM
crazy ICP readings..... twtcad 1999 - 2003 7.3L Power Stroke Diesel 9 10-29-2014 04:55 PM
Tags
0113, 2003, 2005, 60, 60l, circuit, code, diesel, dl, f250, ford, high, iat, icm, input, kam, obd, p1000, problems, reset
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
