You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
It turns over and over just don't start. It is full of oil. I went out tonight and checked and the bowl on top was close to dry. Pulled the cap off and had my son turn the key on and no oil filled the bowl. Help needed
The oil filter housing will not fill up with key on engine off. Pull the fuel filter cap and see if its filling up while cycling the key. Sounds like you may have a oil pressure problem, weather it be low side of high side. If the lpop isnt supplying oil to the hpop it will not fire the injectors to start. I would look closly to find your oil leak and go from there.
__________________ -Scott
SOLD 2-28-11.....
'06 F250 CC/SB PSD. 2'' lift, Bilstein 5100's, Dual stabilizers, 20'' Harley wheels, 35-12.50 MT ATZ's, 08 Mirrors, ARP studs, EGR delete, 4'' MBRP, X3 with custom tunes, Full gauges, scangauge II, Coolant filter, Red top Optimas, DC 185a alt,
I cant tell anything from that video, plus no sound? Do you have any more info? Do you have a way to monitor ICP pressure with a scan tool too see if its a HPO problem?
SOLD 2-28-11.....
bad fuel pump. I just replaced mine on my o2. it's in the frame on the inside under the driver seat[ under the truck]. got a new one from advanced for about $200, took about 45 mins to install
__________________
Charlie slackmaster #26 "A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Quote:
Originally Posted by 67nukeford
Charlie, don't make me come there and kill you...
"If more sane people were armed, the crazy people would get off fewer shots."
you can mist the air breather with a small amount of starting fluid to be sure, if it lightds off, it's the pump. DO NOT START IT ON STARTING FLUID. you can cause a whole lot of damage. just mist the plenum, then crank. it should rap a little like it's going to start.
__________________
no, no fuel, and no buzz when you turned on the key. even left top off filter housing, still no fill. make sure to put in a new filter with the new pump.
__________________
PUT THE EITHER AWAY, in the trash can!!!!!! It has NO BUSINESS BEING ANYWHERE, I REPEAT ANYWHERE NEAR A MODERN DIESEL!!!!!!!! unless you want bent push rods, broken rockers and bridges etc etc or worse. U know how much either it takes to make it through the turbo, CAC pipes and CAC itself? WAY TOO MUCH!
His filter bowl is filling up with fuel so I highly doubt a lift pump is the problem. I strongly feel like he has a HPO problem.
SOLD 2-28-11.....
Thanks for advise silvercrew. I have my air box off were I can see the turbo and that was confusing trying to figure out how in the world the either would get the truck running so I ruled it out of the question anyway. I did check to see if fuel is making it to the top of the motor with help from my son and the answer is yes its flowing!
I am thinking about having it towed to the local diesel shop and getting them to update my software and have them tell me what there high dollar computer says. What do you think???
Well I have not followed your other thread in the 6.0 sectionvery closly, but did you ever get a way to monitor ICP pressure? A scangauge will do it, autoenginuity or even a OTC genysys (or mac mentor or matco) if you can get your hands on one of those and look at ICP pressure it would be a big step. A generic autozone scanner will not read it, it will take something that will read all the enhanced PIDS.
SOLD 2-28-11.....
