Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Crossovers
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
  #1 (permalink)
Old 12-19-2010, 07:27 PM
joelmilot joelmilot is offline
Garage is empty, add now
joelmilot is starting off with a positive reputation.
surging code p0340
Have an 04 monterey 4.2 v6, drove van 2 miles shut it off, started it back up 10 min. later drove back home and 1/2 mile down the van started surging anthing over 35 mph. Limped home, changed fuel filter and took it for a [COLOR=blue !important][COLOR=blue !important]test [COLOR=blue !important]drive[/color][/color][/color], drove 3 miles to store went in side for about 10 -15 min. drove home and about a mile in it started surging again around 45 mph and the check engine light came on. Pulled code P0340 which is camshaft position sensor A circuit (bank 1 or single sensor). Went and googled the code and came up with it either being wiring, camshaft position sensor or camshaft synchro shaft. Replace camshaft position sensor and cleared codes, took for a 20 min. [COLOR=blue !important][COLOR=blue !important]test [COLOR=blue !important]drive[/color][/color][/color] nothing wrong, stop at hardware store came out 10 min. later drove 1/2 mile the surge came back, this time anything over 40mph it would surge. Everytime after it would idle fine and rev up fine in driveway. The sychro shaft looked good and the blade was tight and their is no whining noise coming from the shaft when running. Has anyone else had this problem or have any ideas. Also the code P0340 came back on too. Runs and starts fine just cant trust to drive...
Thanks
  #2 (permalink)
Old 01-06-2011, 08:34 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed is gaining momentum as a positive member of FTE.70f100longbed is gaining momentum as a positive member of FTE.
It could be a bad coil pack causing RFI interference. I fixed a 4.2 e150 today with the same problem.
__________________
Ford senior master tech
Every 5.4 3V owner should have Lisle tool #65600
Tags
340, 42, code, econoline, f150, ford, noise, p0, p0340, p034073, po340, resolve, surging, truck, whining
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
