New f-6 master cylinder brake booster needed
Just as an FYI, so you don't have to search through the OSI books, that part was previously known as A0T-2140-A, according to my original 1955 truck chassis parts catalog.
The same master cylinder was used for both manual and power brakes. I brought up the factory power brake option because he asked about the ebay special.
Ah ha. I think I may get it now. While it's true that the master cyl is the same for many sizes/years,
It is probably a good modification to go to an integral booster/MC like the more modern cars and trucks use nowadays.
I am using the original separate MC and vacuum booster in my F600. I'd keep it that way if I wasn't going to change to a dual (hydroboosted) system.
That is a Bendix Hydrovac. It's a piston actuated brake booster and depending on its size it could work well for an F-6. My 50 F-5 has one of those. F-7 used a similar but larger Hydrovac. A detailed description of its operation and repair is in the Shop Manual.
The original equipment brake booster for 48-51 F-5/6 would have been a Midland Model C447. Same function but diaphragm actuated, looks like a modern power brake unit without the pushrod. That model is obsolete.
52-63 F-5/6 500/600 used a Midland Model C462C brake booster. These are still readily available and often used to replace the earlier units. A slightly different mounting bracket is the only difference. They are available from many medium/heavy duty truck shops and at NAPA. NAPA Part #NBB 518026.
Ha i think ill see if i can get a new or rebuilt one from job lot since im trying to get it as reliable as possiable, But if i need one ill let you guys know. And btw jordan the drums i got from you were really nice, I didnt pull the rear drums yet but will be soon so if there trashed ill be emailing you, I just ordered a set of 22.5 alcoas from rickson wheels and there gonna drill them to my big 5 lug pattern...lots of money....
Must hear more about the 5 lug 22.5's. Are you doing fronts and rears? Would you mind sharing the pricing? TYIA.
I think I've mentioned them before, But Page Brake Page Brake | Locations has the master cylinders for a F6 truck. I picked up a new one for 52 F6 last year, was about $65 I think and is made in the USA
#28
Ill take a pic of the brake system tomm, it dont look like the bendix version like you guys shown, And as far as the 22.5s for 4 aluminum and 2 inner steel is like 2800.00 i think Ha i forget already i know its under 3k. i gave them a 1400 deposit and i think that was half. What the heck its only money right?
#30
