F-350 DRW towing capacities..........
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if !mso]>******** classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui>*********> <style> st1\:*{behavior:url(#ieooui) }st2\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> DRW 5<sup>th</sup> wheel towing – what is the real number?
2011 F-350 DRW limits you to only a 3.73 axle (with or with out limited slip)
The factory full color brochure lists 20,300 on the spec page
The 10/01/10 “major product change” lists 22,600, a 2300 pound increase. That was supposedly due to a frame change in mid August.
The Super Duty “Owners Guide” lists 19,500 with a 3.73, which I assume is a gas engine.
The Power Stroke owners guide supplement doesn’t even list a 5<sup>th</sup> wheel towing, only a GCWR of 30,000.
2011 Ford Towing guide 21,300
All of the “visual” advertising is misleading –“up to 24,500 5<sup>th</sup> wheel. The rating is only for the F-450.
Even the new Ford 2011 Towing Guide you have to search to find that F series towing at 24,400 is a 450.
20,300 Brochure
22,600 10/01/10 Major product change pamphlet
21,300 2011 Ford Towing Guide
21,700 2011 2011 Ford Super Duty | View Towing Specifications | Ford.com
What is it??????????????
How about the receiver hitch?
I have found ratings form 16,000 to 17,500.
20,300 Brochure
******** classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui>*********> <STYLE> st1\:*{behavior:url(#ieooui) }st2\:*{behavior:url(#ieooui) } </STYLE>DRW 5<SUP>th</SUP> wheel towing – what is the real number?
The Power Stroke owners guide supplement doesn’t even list a 5<SUP>th</SUP> wheel towing, only a GCWR of 30,000.
All of the “visual” advertising is misleading –“up to 24,500 5<SUP>th</SUP> wheel. The rating is only for the F-450.
20,300 Brochure
What is it??????????????/
20,300 Brochure
Were you looking at this link?
The 13300 gvwr models should have a 30000 gcwr, where the 13000 gvwr models should have a 29000 gcwr. Subtract the loaded truck weight from the gcwr to get the trailer tow rating. Depending on truck model and options, the trailer tow rating will vary by quite a bit. 30000-8300 (rough empty crew cab drw weight) leaves 21700 for a trailer. Super cabs and regular cabs are lighter leaving more weight for the trailer. Don't forget, every pound you load in the truck lowers the trailer tow capacity.
BDB513
07-21-2014 04:38 PM
JPs2003
28
03-05-2012 10:15 AM
