F-350 DRW towing capacities..........
Old 12-19-2010, 12:24 PM
porthole's Avatar
porthole
porthole is offline
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if !mso]>******** classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui>*********> <style> st1\:*{behavior:url(#ieooui) }st2\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> DRW 5<sup>th</sup> wheel towing – what is the real number?
2011 F-350 DRW limits you to only a 3.73 axle (with or with out limited slip)
The factory full color brochure lists 20,300 on the spec page
The 10/01/10 “major product change” lists 22,600, a 2300 pound increase. That was supposedly due to a frame change in mid August.
The Super Duty “Owners Guide” lists 19,500 with a 3.73, which I assume is a gas engine.
The Power Stroke owners guide supplement doesn’t even list a 5<sup>th</sup> wheel towing, only a GCWR of 30,000.
2011 Ford Towing guide 21,300
All of the “visual” advertising is misleading –“up to 24,500 5<sup>th</sup> wheel. The rating is only for the F-450.
Even the new Ford 2011 Towing Guide you have to search to find that F series towing at 24,400 is a 450.
20,300 Brochure
22,600 10/01/10 Major product change pamphlet
21,300 2011 Ford Towing Guide
21,700 2011 2011 Ford Super Duty | View Towing Specifications | Ford.com
What is it??????????????
How about the receiver hitch?
I have found ratings form 16,000 to 17,500.
Old 12-19-2010, 01:36 PM
Y2KPSD's Avatar
Y2KPSD
Y2KPSD is offline
Originally Posted by porthole
******** classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui>*********> <STYLE> st1\:*{behavior:url(#ieooui) }st2\:*{behavior:url(#ieooui) } </STYLE>DRW 5<SUP>th</SUP> wheel towing – what is the real number?
The Power Stroke owners guide supplement doesn’t even list a 5<SUP>th</SUP> wheel towing, only a GCWR of 30,000.
All of the “visual” advertising is misleading –“up to 24,500 5<SUP>th</SUP> wheel. The rating is only for the F-450.
20,300 Brochure
What is it??????????????/
Were you looking at this link?
Old 12-19-2010, 02:05 PM
porthole's Avatar
porthole
porthole is offline
Originally Posted by Y2KPSD
No I didn't, and that one has another rating, 21700. I'll add that to my original post.
Old 12-19-2010, 07:54 PM
mr176's Avatar
mr176
mr176 is offline
The 13300 gvwr models should have a 30000 gcwr, where the 13000 gvwr models should have a 29000 gcwr. Subtract the loaded truck weight from the gcwr to get the trailer tow rating. Depending on truck model and options, the trailer tow rating will vary by quite a bit. 30000-8300 (rough empty crew cab drw weight) leaves 21700 for a trailer. Super cabs and regular cabs are lighter leaving more weight for the trailer. Don't forget, every pound you load in the truck lowers the trailer tow capacity.
porthole
6.7L Power Stroke Diesel
06-24-2015 12:28 PM
Old_Chipper
07-22-2014 03:21 PM
BDB513
07-21-2014 04:38 PM
JPs2003
28
03-05-2012 10:15 AM
mvedepo
10-05-2010 11:42 PM
Quick Reply: F-350 DRW towing capacities..........
