Where is tachometer located on 1994 F-250?
12-19-2010, 07:14 PM
Where is the tachometer located on a 1994 F-250 460? My tach is dead and needs to be replaced. Just not sure where it is located.
Thanks in advance.
Greg
12-19-2010, 07:21 PM
That makes no sense what so ever.
12-19-2010, 07:40 PM
I mean where is the sensor that measures the RPMs?
12-19-2010, 07:45 PM
Quote:
Originally Posted by
tpcgregsheh
The computer senses it from the ignition sensor, so if the truck runs it isn't that. So it is either the tach itself, the computer or a broken wire.
12-19-2010, 07:50 PM
Bear 45/70
Okay. Thank you.
tpcgregsheh
15
07-14-2012 01:05 AM
banjopicker66
03-25-2010 09:29 AM
aaron59
08-27-2005 05:25 PM
reubenp
1997 - 2003 F150
06-26-2002 10:53 PM
58 ,
73l ,
93 ,
94 ,
f250 ,
ford ,
forums ,
indicator ,
intermittent ,
located ,
location ,
s429250 ,
tach ,
tacho ,
tachometer ,
truck
