Tate's 72 Highboy Restoration. - Ford Truck Enthusiasts Forums
Old 12-19-2010, 12:32 AM
tpdaniels's Avatar
tpdaniels tpdaniels is online now
tpdaniels is starting off with a positive reputation.
I have had a few other threads about the work on this truck, My intentions when I got it was to do a minor clean up and have it painted. Well that didn't last long, so I'm going to combine it all here and maybe something I do will help someone else in their project.
I bought it in Albuquerque New Mexico from the original owners widow. 128,000 miles, her husband was a mechanic and serviced it to death, that along with the dry desert environment is the reason this truck is in such good condition. I have made several hundred pictures so far, I will post progress as I go, I hope to be done by early summer 2011.
I will say right off that the brown on the bottom is history, It will be the deluxe two tone paint scheme, The center and inside will remain Wimbledon White and I am Highly leaning to 69 Ford Arcadian Blue, Here's what it looks like
All the pictures shown on here plus others of the work are located at 1972 Highboy - a set on Flickr
This is the truck when it arrived in North Carolina in August 2010
First work done, Added Power Steering, I did the 78/79 fully integrated system -- Here's a link to the complete Power Steering Conversion http://www.ford-trucks.com/forums/10...-pictures.html
Start of Tear down, around the first of November The next two also show the wheels and tires that will go back on after all work is completed.
Front end removed and bed taken off. Just before the five hour power wash on the frame. (November 30)
I don't have any good pictures of the frame prior to being painted, here is the motor after I repainted all the Blue and Black parts of the engine area. (December 10)
This is the rear frame after painting, the original spare tire is in the background, I am going to clean it like new, repaint the rim and remount under the truck (December 10)
This is my best find so far, 66 Mustang seats and wood steering wheel, I ordered the seat mounts from another member on here, will be mounting for test fit and drilling holes in the next several weeks, going to leave bench seat in until after all work is completed, I'm going to recover them before final install and don't want to damage them. (December 16)
I sent my radiator support and front inner fenders last week to be sandblasted, got them back this week and painted them. I'm using a Sherwin Williams Low Luster Black metal paint on everything that's was black, I do it all with the paint gun, I get a much better job and a gallon of paint goes a long way. After painting the inner fenders, I got a undercoating kit and did the underside of the liners. I have not made a picture of the backside but I will soon. I put on the liner seals that mount with the staples, it took three hours to do two seals and 14 staples, I almost lost my religion over them, a few places on the passenger side did not fit tight so I used 1/8" pop rivets to tighten it up, they look good and can't be seen anyhow. My radiator is also in the picture, I power washed it and sprayed it the same as everything else. I bought a new battery box, the old one had corrosion on it and it was cheaper to get a new one that try to fix the old one.
I worked on the firewall today, December 18, I cleaned and then painted everything white, It started snowing around 12 and I had to quit at 1 pm to go to church, we put together 600 Christmas treat bags to give out tomorrow during Sunday School. I'm going to work on the bottom of the cab next week, it would be easier to do off the frame but no more than it needs it's not worth all the work to remove it and put it right back on. Another reason is I'm doing this by myself, the only help so far is one other person helped me set off the bed onto my trailer, I put it there so it's mobile and I can move it in the shop when I'm ready to work on it.
Old 12-19-2010, 12:35 AM
dmeyer 351 4x4 rebel dmeyer 351 4x4 rebel is offline
dmeyer 351 4x4 rebel is starting off with a positive reputation.
thats awesome man nice job doing my truck this spring
Old 12-19-2010, 06:32 AM
Phil105's Avatar
Phil105 Phil105 is offline
Phil105 is gaining momentum as a positive member of FTE.
REALLY nice truck you have there - and looks like you're doing a nice job on it too. Mine was Wind Blue/Wimbledon White before I repainted it. Here's how those colors looked.
Old 12-20-2010, 06:44 AM
crazed87bronco's Avatar
crazed87bronco crazed87bronco is offline
crazed87bronco is gaining momentum as a positive member of FTE.
very nice looks like it's coming together quite nice for you. props to doing all the work yourself. i wish i had a garage to work in looks like my working on my truck is done until warm weather comes around was hoping it'd be drivable for winter but just didn't make it in time i'll keep an eye on this thread for updates
Old 12-20-2010, 08:15 AM
tpdaniels's Avatar
Quote:
Thanks for including the picture, The Wind blue is the correct 72 color, but it is a little darker than I want to go. Not that I am a Carolina fan but I want something a little lighter like Carolina Blue. The closest two colors I am considering are the late sixties Ford Arcadian Blue and Diamond Blue, It does not have to be year correct for me, It's 38 years old and no one will know the difference so I'm going to paint it what I like.
<a href="http://www.flickr.com/photos/tatedaniels/5277363040/" title="1972 ford blue color compare by tpdaniels, on Flickr"><img src="http://farm6.static.flickr.com/5206/5277363040_bc40c3cd25.jpg" width="500" height="324" alt="1972 ford blue color compare" /></a>
Old 12-20-2010, 09:44 AM
tpdaniels's Avatar
Undercoating on Inner Fenders
This is the backside if the inner fender's after I undercoated them
Old 12-20-2010, 09:45 AM
tpdaniels's Avatar
Transfer case bushings
Transfer case Bushings, I have seen some on here a lot worse, but these had been compressed so long they were doing no good. I could move the case by just pushing on the bottom, new ones stopped all movement.
Old 12-20-2010, 11:30 AM
SixtySix Ford's Avatar
SixtySix Ford SixtySix Ford is offline
SixtySix Ford is starting off with a positive reputation.
great build! keep up the great work! I sure miss my 76 F250 highboy
Old 12-21-2010, 06:23 PM
tpdaniels's Avatar
Inner fender cutout & steering joint boot
I put the front sheet metal back on this afternoon and replaced the rubber boot on the steering shaft slip joint, the pictures show how much I had to cut off of my inner fender to clear the new power steering setup and the boot replacement.
The old and new boots, New boot was $8.00 at my local 4X4 center, it's for a jeep but was just like the Ford factory boot, if it works, use it.
Boot on the shaft, lots of WD-40 and a small screwdriver for persuasion over the stubs, there is more parts that go inside, just did not show them
All put together and ready to install
Installed and ready to go
This shows how much I had to cut out for the power steering setup, I could have gotten by with a little less but I would have had to bend the inner fender way out, looks better like this. I have a rubber cover I made for this cutout but I'm not sure if I'm going to use it. the second picture shows how open it is on my 2010
Today's progress
Old 12-22-2010, 09:11 AM
Quote:
Originally Posted by tpdaniels View Post
where did this A arm come from? isnt your truck a solid front axle? and looks like a alum block........you must have mixed up this pic with another one?
Old 12-22-2010, 10:16 AM
Phil105's Avatar
I'm with you 100% on making it like YOU want it. As you can see in my avatar, I went from blue/white to black/white. As much as any of us may love these trucks, they're just not worth much regardless of how much you put in them - now if they were fat fenders it'd be a little different story to me.
I just wanted you to see how one of the original colors looked on something other than a paint chip.
Enjoy making yours like YOU want it - doesn't matter how somebody else wants it.
MERRY CHRISTMAS
Old 12-22-2010, 10:26 AM
tpdaniels's Avatar
Quote:
I was showing what the cutout I had to do looked like in comparison to what my 2010 is like from the factory, it was in small print above the picture. I will try to do better next time
Old 12-22-2010, 11:29 AM
Danger_Dave's Avatar
Danger_Dave Danger_Dave is offline
Danger_Dave is gaining momentum as a positive member of FTE.
whats that guard pan that you have under the core support on the last picture?
Old 12-22-2010, 05:51 PM
tpdaniels's Avatar
Quote:
That's the top of the shock/spring assembly, the reason it look's funny I put a 2" leveling kit on the truck and the way you do it is by adding a special made spacer on top of assembly. Here is what it looked like before adding 2" to the front, it now sit's almost level
[/IMG]
Old 12-24-2010, 05:08 PM
tpdaniels's Avatar
Bucket Seats, Trail Install
I can't believe I spent part of Christmas Eve working on the truck, The wife left early to go shopping and I was going to just take it easy. All that changed around 10 when UPS delivered my new bucket seat floor mounts. I thought I would just open them for a test fit on the seats, that looked so good, one thing led to another, next thing I know I have the seat out, floor mat removed and the bucket seats sitting in the truck. Being that they are in the truck, I might as well drill the holes needed for the inside brackets, that done I bolted them down, made a picture and decided to quit. Here's what they look like now, it will look a lot different when they have been recovered and the cab redone inside.
Merry Christmas
1974 Ford F-100 Ranger billymfh 1973 - 1979 F-100 & Larger F-Series Trucks 18 03-13-2013 05:20 PM
Ignition actuator help paulwjax 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 05-17-2011 08:46 PM
Paint Issue 2007F150FX4 2004 - 2008 F150 12 03-29-2011 07:34 PM
My 66 F250 Restoration ParkStreet 1961 - 1966 F-100 & Larger F-Series Trucks 20 03-22-2011 09:34 PM
Rear fuel tank, "Highboy" ??? tpdaniels 1967 - 1972 F-100 & Larger F-Series Trucks 3 03-01-2011 09:25 PM
Tags
69, 72, 72highboycom, arcadian, blue, f250, ford, highboy, lights, market, metal, moto, project, restoration, truck, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
