1990 F250 Ignition Lock
I'm trying to get an old rig back on the road. It's been sitting about 4 months.
I find the key is VERY hard to turn. It has a tilt steering wheel, but the position makes no difference. The front wheel position makes no difference. It's always hard to turn. It reaches a rotation point where it lights the glow-plug light, but no farther.
It was about 30 degrees when I had the problem; it rotated freely a month or so back at 50 degrees.
If you remove the top plastic cover on the column between the steering wheel and the dash, you will find an item called an ignition switch activator made of aluminum. They will break.
If you can just lift the cover you may see it, in a pinch you can turn the key on and useing a screwdriver to push the activator start the vehicle.
Other than that ...... key on jumper the starter relay on the fender.
Note: Do it in park or nuetral depending on the trans.
AJParry89
19
03-11-2013 08:19 PM
Lane Dexter
11-08-2004 04:15 PM
Jet Lizard
05-11-2004 01:06 AM
aquery
06-30-2003 02:41 AM
