Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-18-2010, 08:16 PM
jcork jcork is offline
Garage is empty, add now
jcork is starting off with a positive reputation.
1990 F250 Ignition Lock
I'm trying to get an old rig back on the road. It's been sitting about 4 months.
I find the key is VERY hard to turn. It has a tilt steering wheel, but the position makes no difference. The front wheel position makes no difference. It's always hard to turn. It reaches a rotation point where it lights the glow-plug light, but no farther.
It was about 30 degrees when I had the problem; it rotated freely a month or so back at 50 degrees.
  #2 (permalink)
Old 12-18-2010, 10:26 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
1988 Ford F-150
My Garage
IDIDieselJohn has a very good reputation on FTE.IDIDieselJohn has a very good reputation on FTE.IDIDieselJohn has a very good reputation on FTE.
All my Fords have/had that problem.
Remove the steering wheel, clean and grease the lock mechanism.
__________________
1990 Ford F250 4x4, ZF5, L/S 4.10, N/A 7.3L Diesel, 568,808km/377,497 miles, still on the original clutch!
1989 Ford F150 300-6, C6, 2.73, 127,000km/79,000 miles.
1987 Ford E350 26ft. Motorhome, N/A 6.9L Diesel, C6, 3.54, 265,000km/166,000 miles.
1985 Ford E350 Ext Van, 6.9L Diesel, C6, 4.11, 658,000km/411k miles
  #3 (permalink)
Old 12-19-2010, 09:42 AM
Thanx for the tip. I'll try that.
  #4 (permalink)
Old 12-19-2010, 10:36 AM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
If you remove the top plastic cover on the column between the steering wheel and the dash, you will find an item called an ignition switch activator made of aluminum. They will break.
If you can just lift the cover you may see it, in a pinch you can turn the key on and useing a screwdriver to push the activator start the vehicle.
Other than that ...... key on jumper the starter relay on the fender.
Note: Do it in park or nuetral depending on the trans.
__________________
93 F250 SC 4x4 E4OD 355LS
  #5 (permalink)
Old 12-19-2010, 06:57 PM
That brings up an interesting question ...
how to you STOP the engine once you get it running (if the controls aren't working)? Are the brakes in 4th enough to stop a 7l diesel?
  #6 (permalink)
Old 12-19-2010, 07:03 PM
1988 Ford F-150
My Garage
You have to have your key in the ON position to jump to the fender....
Then to kill it, simple turn key off.
And yes brakes in 4th will kill it no problem.
__________________
Tags
1988, 1990, 73, break, cylinder, f250, ford, idi, ignition, lock, locked, remove, steering, wheel, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
