ok how got a ttb 50 they want to off load
on
bghnkinf,
but Joe needs SRW hubs.so dually adapters or dually hubs will just put him back where he is now.
besides what is it you don't like about the front dually adapters?
are they good quality from arrowcraft?
you understand you would need new rotors to swap as well.
Joe what you have are worth $.
there's no such thing as a front D60 "dually axle" per-say.its just the hubs/rotor combo.
so when you list the dually hubs for sale,include the rotors.because the buyer will want them.
the singles are the low cost ones like powerstroker says.
found everywhere.
and Joe,im still totally lost with the title of this thread?
who has the TTB D50? and what are you trying to do with that axle?
found everywhere.
on
on
oh you don't have to worry about arrowcraft's goods.iv done a lot of researching and they are well known for being high quality.front and rear adapters both.
centurion-the high quality conversion guys use arrowcraft for their conversions front and rear.that should tell ya something right there too.
im running arrowcraft front dually adapters myself.good stuff!
http://www.arrowcraft.com/index.php
they're holding that diesel and an 8' fisher plow with no problems.
at first i thought about saving a little $ by buying from some other place.glad i didn't lol.i posted info and warning latter with what i found:
https://www.ford-trucks.com/forums/9...-adapters.html
Received 3,107 Likes
on
These are not bolt-on hub extenders, they are genuine dually-specific hubs - look where the rotor is bolted to them, if they were actual hub extenders you'll be able to see nuts on the outer side of that flange the rotor is on. They actually look damn near the same as my 2wd dually hubs, well i know they are not identical but the design is the same - giant extra-wide one-piece hub, rotor bolts up to the inboard side, wheel goes on the outboard side.
