Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > New England Region > Massachusetts Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Massachusetts Chapter Join Chapter, Leader: donjamer
  #1 (permalink)
Old 12-18-2010, 08:13 PM
99offroadrngr's Avatar
99offroadrngr 99offroadrngr is offline
Garage is empty, add now
99offroadrngr is new and has a neutral reputation at this point.
Need some help or referrals
The rear axle on my truck (1999 Ford Ranger) is acting up pretty bad it ticks, clunks, etc. I have another axle here at home but it needs a limited slip installed with the same gear ratio and the pinion gear hasn't been moved. The ring gear will be on the trac lock already all it needs to be is installed in the axle itself. I've been told that since im using the same gear ratio that the lash is 99% of the time unchanged making it an easier job.
Now, my problem is that I've never done something like this in my life and rather not do it and make a mistake that could end up costing an arm and a leg.
Does anyone know how to do this kind of stuff or know of a place that will do it for under $300? I took it somewhere near home and they want 3-400 to just install the limited slip even with the axle being out of the truck. The cheaper the better, I don't have much money since i jsut started winter break from school and haven't worked much.
I plan to have the brakes swapped to mustang discs (already have the parts) but i might be able to find someone locally to give me a hand with that.
any help would be great!
Thanks
  #2 (permalink)
Old 12-22-2010, 07:33 AM
BIGKEN's Avatar
BIGKEN BIGKEN is offline
So Little To Say!!!
BIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputation
Any luck finding someone???
__________________
Member of the Massachusetts Chapter and Number One Winter Hater!!!
Some days...the best thing about my job is that the chair spins!!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
