1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2000 Ford Expedition Ticking/ tapping in under the hood
Old 12-18-2010, 02:40 PM
singr_69's Avatar
singr_69
singr_69 is offline
I have a ticking/ tapping sound in my SUV. Does anyone have any clue what could possibly the problem? Help Please
Old 12-18-2010, 03:01 PM
alloro's Avatar
alloro
alloro is online now
Received 4,194 Likes on 2,430 Posts
It could be several things like a fuel injector, a valve lifter, a solenoid, a spark jumping to ground, and exhaust leak, etc. You need to try and narrow down where it's coming from for us to be able to give you guidance.
Old 12-18-2010, 04:48 PM
singr_69's Avatar
singr_69
singr_69 is offline
it is a consistant ticking sound from the engine.
Old 12-18-2010, 05:17 PM
alloro's Avatar
alloro
Originally Posted by singr_69
it is a consistent ticking sound from the engine.
The top, the bottom, the front, the rear, the left side, the right side, only when reving the motor, only when at an idle, etc....
You've got to give us something to go on, we're not there, you are.
Old 12-18-2010, 05:59 PM
singr_69's Avatar
singr_69
singr_69 is offline
sorry. Top. and it is constant doesnt change when idleing up or down
Old 12-19-2010, 08:49 PM
crabjoe's Avatar
crabjoe
crabjoe is offline
I've got the same thing. You can't hear it from inside. Mine goes tap ..... tap tap ..... tap ..... tap tap. The sound is almost like a AC compressor engaging and dis-engaging and I can't tell where on the motor it's coming from.
Old 12-19-2010, 09:15 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
Check your email.
Old 12-19-2010, 09:20 PM
crabjoe's Avatar
crabjoe
crabjoe is offline
Originally Posted by Moto Mel
Check your email.
Come one ... If you have any idea what it might be, let us in on it. I've got a tapping I can't figure out either.. :-(
Old 12-20-2010, 12:17 AM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
I only have a guess that no one would want to hear. I live near Singr and might be able to ID the problem for him. I don't have a shop and I don't work on other people's stuff either. I do have a lot of tools though.
Old 12-20-2010, 07:22 AM
Big Greenie's Avatar
Big Greenie
Big Greenie is offline
Temporarily Deactivated
All you could do is make a wild guess from what we have been told so far.
Guys, there are a hundred moving parts under the hood, to say it is ticking doesn't help...
Does it go away once the engine has warmed up? Is the rate of ticking related to the rpm?
Could be the exhaust manifold leaking, that usually goes away when warm unless it has been doing it for a long time.
Could be a spark plug getting ready to blow out
Could just be the typical cold engine noise most of these engines make.
Fuel injectors are apretty soft tick, usually not heard with the hood closed.
Timing chain tensioners could be bad leading to several different noises.
So short of someone like Mel offering to come take a listen, you are going to have to help narrow it down on your end before anybody can be much help here.
Old 12-20-2010, 12:43 PM
aft2005exp's Avatar
aft2005exp
aft2005exp is offline
'05 EXPY 4x4 105k here.. I'm not a professional, but here is my experience. Had a ticking sound under the hood.. Was a constant sound.... Sound was on top half, on passenger side.. Also was sluggish.. Brought it to a local independent guy who was able to diagnosis and repair it. The timing chain tensioners were disintegrating and the bits of plastic were clogging the flow of of oil into the passenger side of the engine.. So we replaced the timing chains, tensioners and associated parts that were jammed with plastic from the originals, and voila ticking sound was gone, and performance improved. Not sure this is your engines issue. but just a possibility based on my experience.. Good luck !
Old 12-20-2010, 03:53 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
That is often the cause of a lot of engine noises and failures. Glad you found an honest and capable mechanic that saved your engine.
Old 12-20-2010, 03:58 PM
Londart's Avatar
Londart
Londart is offline
what about ticking sound when cold goes away if you rev or once warmed up....lifter?if so does seafoam or lucas usually fix this or do i have to dig in?
Old 12-20-2010, 04:05 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
If you have a light ticking sound when first starting that goes away after a few seconds it is usually the cam chain tensioners. If it only goes away when you rev the engine there are usually other problems to be addressed.
Old 12-20-2010, 04:11 PM
Londart's Avatar
Londart
Londart is offline
it is just light ticking...sounds like the older cars when you needed to adjust rocker arms
Quick Reply: 2000 Ford Expedition Ticking/ tapping in under the hood
