Duraspark II module need grounding ? - Ford Truck Enthusiasts Forums
Old 12-18-2010, 11:50 AM
Derrick lane Derrick lane is offline
Derrick lane is starting off with a positive reputation.
Ha'yall Dose the duraspark II module need to be grounded ?. I mounted mine on the fender-well that is plastic and wondering if I should of hooked a ground wire to it. As the truck runs kinda funny sometimes when wet / cold tries to die.
Thanks.
Old 12-18-2010, 01:43 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
The factory mounted the DS2 box to the plastic fender, and I don't recall seeing a grond wire attached to mine.
The box should be grounded thru the wiring itself.
Old 12-18-2010, 01:58 PM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
I would, it is a good idea to ground it. All of mine have been on metal fenders, but I run a seperate ground wire to the case anyway. Of course, I'm a ground freak. Can't swear it makes a diff, but I've never had one fail, maybe just lucky.
Old 12-18-2010, 04:20 PM
Don Senkow Don Senkow is offline
Don Senkow is starting off with a positive reputation.
Dura Spark grounds thru the black wire in the distributer. Sometimes you can have problems with the ground there. Don
Old 12-19-2010, 01:43 AM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
As stated, it grounds through the distributor, no connections to the case inside so no point in grounding it-
I have had a bad ground at the distributor before and wound up splicing into the black ground wire to run a lead to the battery negative terminal. Never had an issue after that.
Is there a Duraspark II "kit" out there reamer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 11-13-2016 09:24 PM
Best duraspark II module replacement... 460me 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-03-2016 12:44 PM
Painless Duraspark ii question Mgbarre 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 05-05-2016 10:30 AM
Duraspark II Ignition Module LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 38 01-09-2016 01:48 PM
New Design Duraspark Ignition Module? LARIAT 85 Electrical Systems/Wiring 16 06-17-2013 09:19 AM
Tags
11, 1980, 4wd, distributor, duraspark, f150, ford, ground, grounded, grounding, grounds, identification, ignition, ii, module, ranger, specs, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
