side air bag/ fron seat removal
I apologize if this too long to read....I am planing to pull the front seat to look at heat issue with climate control and i reviews the factory manual and i am looking more clarification on this one..... I know the location of sensor and i can deplete power by disconnecting battery....
This is what it says in factory repair manual....
NOTE: Airbag simulators (restraint system diagnostic tools) MUST be installed under the seats in the side airbag to floor connector.
NOTE: Diagnostics or repairs are not to be performed on a side airbag system with the seat in the vehicle. Prior to attempting to diagnose/repair the side airbag system, the seat must be removed from the vehicle and the restraint system diagnostic tool must be installed in side airbag connector at the floor connector. The restraint system diagnostic tool must be removed prior to operating the vehicle.
NOTE: Diagnostics may be performed on seat systems other than the side airbag system (lumbar, climate controlled, heated, power seat track) with the seat installed in the vehicle, as long as the restraint system diagnostic tool is installed under the seat in the side airbag to floor connector.
My question is even i disconnect the battery and eventually there is no power, do i still need to have RS tool connect to side airbag to floor connector..?
Thats what was my uderstanding too but i get confuse when it says MUST install the tool in the seat connector even no battery power...
Thanks Mel
I will disconnect the battery for sure .....i am sure dealer way is book way and also money making tool for them.
Craig you are right. I just spoke to the someone at dealer and he told me that as long as you disconnect the battery, you are safe and he also said his guys have simulator which they hook up with that. My concern was safety and he said it's all good. Now i can repair the seat cover from inside and also check on heating pad....
Ok, done with seat repair. I disconnect the battery and wait about 10 minutes and pull the connector apart and removed the seat. Back portion of leather cover is glued in with foam so i only left the front portion of it. Seat cover was torn apart almost 8 inches, i used the strip of leather and glue it in from inside.
It looks pretty good and hard to notice the torn apart area. Happy with repair. Put everything together, connect the side air bag connector and battery. No problem and no issue at all....
Yes, i am keeping my finger cross. New cover is too expensive at dealer... so ebay will be the place...sometime ago i saw exact leather cover on ebay , i don't recall if it was OEM or aftermarket....
Dragon600
2004 - 2008 F150
01-05-2013 10:34 AM
Nitro Blazer
02-28-2012 01:15 PM
